Slow down Kirsty - first things first - the fact sheet will be created. Trust me on this one.missfixit70 wrote: It looks like someone's going to have to factsheet this lot before it all gets lost/pruned/forgotten![]()
Yep............ agree with thatdandywarhol wrote:Here's my thoughts on the workings of the cooling system. I somehow picked up from previous threads that the thermostat "pointy end" faced up the way - now that its been confirmed otherwise I can make sense of whats happening. If this has already been said in previous threads then apologies.
On "conventional" cooling systems with the 'stat at the outlet from the head the cold coolant heats up in the water jackets and convects upwards towards the thermostat. It does't get past the 'stat at this stage but circulates by a bypass system back round to the waterpump and further convects until it is hot enough to open the 'stat. The 'stat valve is opened by the wax contained in the "bulb" of the thermostat expanding through heat and it opens the valve. There's always coolant at either side of the 'stat (assuming no airlocks) - its the heat transfer by convection thats taking place through the coolant which keeps the cycle going.
The hot coolant, at around 90 degrees, then transfers to the radiator and depending whether it is a crossflow or vertical flow type, travels through the radiator which, as the name implies, radates the heat to the atmosphere. Because modern vehicles have the lower tank on the radiator at a position lower than the engine block, the waterpump then lifts the cooled, dense coolant back up into the engine. Then the coolant recircluation cycles starts all over again.
Now for the Bongo system........................
I think it was TGP who said the waterpump is actually "pumping" coolant around the system on the Bongo, I contradicted him.................and he is right! The Bongo system, with the 'stat in the return to the engine setup does rely on the pump “pumping” the coolant around the engine, whereas the “conventional” setup has the pump “lifting” the coolant from the lower radiator tank to the engine block.
Righto……………I think this is what happens.
The cold coolant is warmed by the cylinders, the waterpump assists the heat travel process by taking coolant from the bypass system above the thermostat (the ‘stat is closed at this point but the disc shaped valve (seen in Allans excellent pics mentioned by Kirsty), is open allowing the bypass system to be open. The coolant heats up, convection currents lift the coolant to the highest outlet in the head, to the pipe seen under the driver’s seat and directly forward to the top of the radiator. As the hot coolant mixes with the cold coolant in the radiator its easiest path for heat transfer is to go up to the expansion/auxiliary tank (because heat rises and the radiator coolant isn’t allowed to circulate at this point due to the closed thermostat not allowing circulation). This hot coolant circulates through the expansion/aux. tank and carries on to the heater circuits and ends back in the previously mentioned bypass system above the thermostat. The waterpump then takes the coolant back from the bypass into the engine block. From memory, there are no external coolant hoses on the pump – it just takes coolant from A to B internally.
The coolant in this system, including the block/head/hoses/metal pipes/radiator top tank/heater matrices/turbo cooling system and various metal pipes will be staying at a fairly uniform temperature. Fluctuations will occur (probably as previously mentioned the reason the gauge is damped) but the volume of coolant and expanse of piping does its job in keeping the system at a safe working temperature, just below thermostat opening temperature. There will a few “glitches” when stopped in traffic/hill climbing/hot ambient temperatures when the coolant temperature will be high enough to heat the “bulb” on the ‘stat enough to open the thermostat. And as the coloured diagrams that Mike Gough posted of the Elise/MG system shows, there will be a mix of bypass coolant and some colder coolant allowed to enter the system from the radiator, via the now partially opened thermostat. This would explain the temperature fluctuations recorded on the TM2 gauges.
If the conditions then really demand extra cooling then the ‘stat will fully open, the bypass system will close off by the disc shaped valve and the entire cooling system will constist of the block/head/outlet hose under the driver’s seat/radiator/lower radiator tank/thermostat/expansion, aux.tank/heaters et al until things cool off enough to partially close the ‘stat again and the system reverts back to the former setup. The closed off bypass system then allows the warm coolant from the radiator bottom tank to go past the thermostat directly into the engine block. Allan’s photos show this.
If this the case, then vehicles used in cold climates in Japan or Europe might rarely have the complete system functioning in full flow and possibly why the radiators in these vehicle choke up.
Thanks for reopening this one widdowson, I think it’s becoming clearer through time……………………….and nobody has fallen out …………………..yet!
Yep............ agree with that![]()
and explained as clear as I could, although perhaps if a "dummies guide" type of Fact sheet is produced it could also point out the weaknesses of the system and why bleeding is done in a particular way and also benefits of any monitoring add ons..... Just a thought
That's exactly what's needed![]()
but that's a lot of info for someone to put together, brave person that takes it on
Fully agree, as I have been advocating for a whilemikexgough wrote:Personally now, I would incorporate and recommend a Thermostat change when the coolant is changed followed by the full bleed process and all should be well in the world, for the nominal cost of a Thermostat it could prevent a lot of hassle.
Can I also thank all the contributors to the thread for their intelligent debate and analytical way we have discussed this topic.... well done folks...![]()
haydn callow wrote:Dandy said.......The coolant in this system, including the block/head/hoses/metal pipes/radiator top tank/heater matrices/turbo cooling system and various metal pipes will be staying at a fairly uniform temperature. Fluctuations will occur (probably as previously mentioned the reason the gauge is damped) but the volume of coolant and expanse of piping does its job in keeping the system at a safe working temperature, just below thermostat opening temperature. There will a few “glitches” when stopped in traffic/hill climbing/hot ambient temperatures when the coolant temperature will be high enough to heat the “bulb” on the ‘stat enough to open the thermostat. And as the coloured diagrams that Mike Gough posted of the Elise/MG system shows, there will be a mix of bypass coolant and some colder coolant allowed to enter the system from the radiator, via the now partially opened thermostat. This would explain the temperature fluctuations recorded on the TM2 gauges.
Having just spent a hour with a Pan of water on the stove and a Thermostat and Stat housing......I think the above is a "spot on" description of exactly what goes on....
Even better..I understand it...
I have always made a point of "forceing" my bottom hose hot every now and again......Would I be right is saying that a Stats default mode is OPEN in the case of failure ??
