Page 5 of 5
Re: Bongo Free Top weather seal.
Posted: Tue May 24, 2011 10:36 pm
by nicstrike
Posted: Tue May 24, 2011 10:40 pm
by missfixit70
Maybe, but not comprehensive enough. Have you actually looked at what is needed?
Posted: Tue May 24, 2011 10:43 pm
by nicstrike
yes...i have also read their homepage which says if you cant see what you want they will endeavour to source for you!
Posted: Wed May 25, 2011 1:20 pm
by missfixit70
I think the bongo seal may not be a simple one to reproduce as it has a metal insert in the bit that grips the roof, but if someone wants to pursue that option for a group buy, they could be on to a good thing.
I'm not saying it isn't out there & available cheaper than buying from Mazda, but I spent a lot of time trawling a lot of suppliers with no luck.
If someone is genuinely interested in pursuing this, then the way to do it is NOT to keep posting up links saying "what about this one?", but to look at the lists & see if there is anything comparable to the original seal and/or ask the companies direct about sourcing/manufacturing it. I did not pursue this angle.
Good luck
Posted: Wed May 25, 2011 1:24 pm
missfixit70 wrote:I think the bongo seal may not be a simple one to reproduce as it has a metal insert in the bit that grips the roof, but if someone wants to pursue that option for a group buy, they could be on to a good thing.
Good luck
When all is said and done, I don't think the price you paid is that bad for a specialist genuine part on an ageing Jap import. I'll be interested to hear how you get on fitting it and may get one for mine, as it shows signs of getting a bit tired at the front end corners (though I think it wil go for a few more seasons with TLC).
Posted: Wed May 25, 2011 6:54 pm
by nicstrike
Good luck
i wont bother pursuing it as i dont need one (at the moment) , i was meerly trying to help & offer some alternatives! i'll spend my time more productively...varnishing the dog or something like that!!
Posted: Wed May 25, 2011 7:50 pm
by rita
nicstrike wrote:missfixit70 wrote:I think the bongo seal may not be a simple one to reproduce as it has a metal insert in the bit that grips the roof, but if someone wants to pursue that option for a group buy, they could be on to a good thing.
Good luck
Dont let the poor wee thing catch Distemper.
Posted: Wed Jun 15, 2011 7:34 am
by mikexgough
Any of these any good?...... the price is....
if any of them are up to the job...
One
Two
Posted: Wed Jun 15, 2011 11:32 am
by missfixit70
Nope, same ones that are on all the lists
Needs to be the same profile as the one on the left (Is anyone actually reading through the post before posting the same profiles again & again?
I can also confirm it is not an easy job to fit the seal due to the 2 areas behind the rear hinges that are very close to the bongo body & the hinge itself, I had to unbolt the hinges (one at a time & force the roof back & up a bit (front of roof also then needs supporting - iused a 3m piece of wood) using a one handed clamp jobby used as a kind of jack, bloody awkward, still got the bruises to prove it, Ideally it's at least a 2 person job.
Start from the front, lining up the "cut outs" on the seal - ideally having marked where those are on the inside of the roof before removing the old one.
Posted: Wed Jun 15, 2011 8:09 pm
by mikexgough
Just offered an option after seeing a Westy 2 weeks ago and chatting over a beer with the owner sharing ideas....the seal looked much like the Bongo one in the pictures....as it is compressed under when the roof is down..... If it aint no good ...well nowt lost in a suggestion...
