REMOTE LOCKING
jaylee
Re: REMOTE LOCKING
Post by jaylee » Sat Oct 23, 2010 10:23 am
rabbo wrote:Hi,
Yes I did read that several times. It just says connect the wiring to the existing central locking wiring but not any more specific than that, not being familiar with the electrics I don't know which to connect and the rclick manual doesn't seem to be much help.
Any chance of scanning it in & posting the manual up??
Scott
Re: REMOTE LOCKING
Post by Scott » Sun Oct 24, 2010 7:24 pm
This any good
The user formerly known as csmcqueen ;)
スコット
rabbo
Re: REMOTE LOCKING
Post by rabbo » Mon Oct 25, 2010 7:39 am
Thanks again for your replies.
Yes that diagram is exactly my unit, I will try to connect it as shown and let you know.
Thank you very much
Andy
Re: REMOTE LOCKING
Post by g8dhe » Mon Oct 25, 2010 9:58 am
The text for the Bongo Rapid fit does not match the pictures !
It says;
1. Connect Orange, Yellow, Black to negative supply
and
4. Connect Orange/Black, Yellow/Black and fused Red to positive supply
These instructions do not match the pictures.
I believe you should be connecting Orange, Orange/Black and Black to negative supply,
and Yellow, Yellow/Black and a fused Red to positive supply,
if you believe the pictures.
rabbo
Re: REMOTE LOCKING
Post by rabbo » Mon Oct 25, 2010 12:06 pm
Yes that is correct!
I followed the diagram and the actuator was permanantly on.
So it should be Orange, Orange/Black and Black to negative supply,
and Yellow, Yellow/Black and a fused Red to positive supply.
Thanks very much for all your help.
RClick didn't come back to me at all and the diagrams really wern't much good so I wouldn't have been able to do it otherwise!
:D
Scott
Re: REMOTE LOCKING
Post by Scott » Mon Oct 25, 2010 8:01 pm
g8dhe wrote:The text for the Bongo Rapid fit does not match the pictures !
It says;
and
b*gger typo, well spotted :oops:
orange, orange/black and black do indeed go to negative and the yellow, yellow black and red go to a permanent live supply. :D
スコット
jcozens
Re: REMOTE LOCKING
Post by jcozens » Tue Oct 26, 2010 6:17 pm
hi I have also bought one of these is it right I will need a actuator as well then ? I got mine from www.ultimatecarparts.co.uk
jaylee
Re: REMOTE LOCKING
Post by jaylee » Tue Oct 26, 2010 8:00 pm
jcozens wrote:hi I have also bought one of these is it right I will need a actuator as well then ? I got mine from http://www.ultimatecarparts.co.uk
You will indeed... The actuator drives the existing manual factory system via a simple connecting rod, locking & unlocking by remote!
rabbo
Re: REMOTE LOCKING
Post by rabbo » Tue Oct 26, 2010 9:19 pm
one last question!
Is it right that once the remote central locking is locked and the blue light flashes (the arming light that plugs into the brain) when you manually unlock the doors from the drivers door the system doesn't register this and the blue light continues to flash?
This could become annoying!
jaylee
Re: REMOTE LOCKING
Post by jaylee » Tue Oct 26, 2010 10:12 pm
rabbo wrote:one last question!
I have a different alarm CL system.. Generally (depending on the system) the blue flashing light should only flash when armed (locked) some blue (or red leds) light constantly if in valet mode?!!
Manually unlocking the door & opening while armed will (& rightly should!) trigger the alarm... It's an independent system that ties in with the factory manual locking...
Colin H F
Re: REMOTE LOCKING
Post by Colin H F » Thu Oct 28, 2010 12:29 pm
thats exactly what mine does , as it has`nt recieved the command from the key fob
fanx_ta_ra
Re: REMOTE LOCKING
Post by fanx_ta_ra » Thu Oct 28, 2010 12:44 pm
Hi All
Been reading this thread with interest and absorbing all the excellent info =D> . I have a Toad Ai606 alarm and immobiliser fitted to my Bongo. I am sure that I could use the brains of this alarm and the fob to control a central locking acctuator but I need to know if I would I need to buy the 2 or 5 wire version.
Kind Regards, Andy
jaylee
Re: REMOTE LOCKING
Post by jaylee » Thu Oct 28, 2010 12:51 pm
This may have some bearing..? If your fob battery's are OK..? Some units can be taught the fob code, so if you lose one the brain box can be re-set, when you get a new fob, you teach it the code.. I had some similar problems a few months back with my alarm, thought it had something to do with the receiver..? (got the lcd fob that notifies me if the alarm gets triggered.) Anyway i just re-set & re-taught the fob code! Consult the instructions...
jaylee
Re: REMOTE LOCKING
Post by jaylee » Thu Oct 28, 2010 12:53 pm
fanx_ta_ra wrote:Hi All
Kind Regards, Andy
2 wire should do the job! :D
Scott
Re: REMOTE LOCKING
Post by Scott » Thu Oct 28, 2010 4:29 pm
Thought I would delete the old one so it did not cause too much confusion :)
スコット
