coolant flow - (follow up to cooling diagram)
Re: coolant flow - (follow up to cooling diagram)
Post by Doone » Wed Nov 24, 2010 2:58 pm
......and what do the 'twisties' actually do? cos mine's got 'em too.
AFAIK they enhance tube side heat transfer efficiency... as far as I know. :)
Post by g8dhe » Wed Nov 24, 2010 3:13 pm
widdowson2008 wrote:..and what do the 'twisties' actually do? cos mine's got 'em too. :D
They cause the water to flow in a turbulent manner, rather than a laminar flow, this means that you get better heat transfer. If its a laminar flow then the water closest to the metal flows slower and very smoothly and "insulates" the water further from the metal and hence slows down heat transfer. Turbulent flow means you get little swirls and ripples which in turn means all the water gets to cool down / transfer heat evenly.
widdowson2008
Post by widdowson2008 » Wed Nov 24, 2010 3:24 pm
Yep - go along with both those answers for no other reason they are logical and make total sense. =D>
Just got the physical shape/dimensions from Helen (who is getting a pic for me tomorrow). Apparently, they are flat - we'll see. ....to be continued. :lol:
.....moving on.......
In the process of chopping further to find the next answer (probably find out tomorrow), but I'll throw it in for suggestions anyway. Both the inlet and outlet are on the same side whilst the tubes are horizontal. Question is, how does coolant flow horizontally, yet come back to the same side of the heater?
ps Keep it up Helen =D>
Steve
mikexgough
Post by mikexgough » Wed Nov 24, 2010 3:35 pm
widdowson2008 wrote:Don't think it would be quite that simple a task TBH Ron. Take the stat for example. On the surface, the pattern stat looks identical to a Mazda one, but like the Heinz/Sainsbury ketchup analogy, it's the missing ingedient that makes the difference.
When pattern parts are made, they are generally produced to the same specification as the original - material, tolerances, etc. The pattern stat is different in (at least) one aspect. It has the extra stem seal which makes it (IMHO) the better (though more expensive) option.
Whoever took on this task would need to be able to SPOT the difference(s) - a time consuming excercise.
Happy to research the parts and source supplies of the O.E parts in the makers packaging .....be a long job and may need help with some part numbers off of the "Mazda" parts .....mainly from the bodies of them not the Mazzy factory part numbers :wink:......
widdowson2008
Post by widdowson2008 » Wed Nov 24, 2010 4:40 pm
mikexgough wrote: Happy to research the parts and source supplies of the O.E parts in the makers packaging .....be a long job and may need help with some part numbers off of the "Mazda" parts .....mainly from the bodies of them not the Mazzy factory part numbers :wink:......
That would be a job WELL worth doing Mike. =D>
If I can be of any help, then all you need to do is to ask.
Because this is important, I think it should be done under a topic in its own right (ie: another thread), for two reasons:
1 - It risks being burried within a thread such as this one and a REAL pain to find when needed.
2 - It would avoid defragmentation of the 'host' thread. ie: losing the thread of the thread, (if you know what I mean)
Gonna start one Mike?
Steve
helen&tony
Post by helen&tony » Wed Nov 24, 2010 4:49 pm
The "Further Choppings" will happen tomorrow...and the plastic thingies aren't like Dandy's one
Geoff...you get the star prize...LAMINAR FLOW...Don't ask, or I'll bore you till Hell freezes over on that one :lol: :lol: :lol: :lol: :lol:
Post by g8dhe » Wed Nov 24, 2010 5:25 pm
widdowson2008 wrote:Question is, how does coolant flow horizontally, yet come back to the same side of the heater?
Perhaps the inlet tube is blocked half way along, so the water has to flow up thru the fins to the top pipe, then back down the other side, so half of the fins have water flowing up them and half have the water flowing down them back to the outlet ?
widdowson2008
Post by widdowson2008 » Wed Nov 24, 2010 6:54 pm
Sorry Geoff - must be me but I cant picture that..........Sketch needed :lol: (of your thoughts)
Steve
Post by g8dhe » Wed Nov 24, 2010 11:51 pm
OK found this picture which I have drawn on;
dandywarhol
Post by dandywarhol » Wed Nov 24, 2010 11:52 pm
dandywarhol wrote: And a pic of a discected matrix - the "twisties" are known as turbulators in the industry
OK - Just got my own pics from Helen of a dissected front heater. BLOODY FASCINATING to say the least. 8)
Requested Helen to do even MORE cuts as the flow path isn't apparent (to me at least.)
Also asked for physical sizes so I can put some numbers around it.
Didn't realise at the time Dandy posted the above pic, but it looks very similar to the ones I have. Is that one from a Bongo Dandy?Just checked - don't think it is from a Bongo - less tubes (unless this is a rear heater?)
......and what do the 'twisties' actually do? cos mine's got 'em too. :D
I'LL BE BACK.
BTW - keep that up Ady - should make an interesting read =D> =D>
Will this ever end mother? :(
don't know what it's from - just found it on the 'net
widdowson2008
Post by widdowson2008 » Thu Nov 25, 2010 12:08 am
Thanks Dandy.
Have you seen the flow that Geoff posted? Now that is starting to make a bit of sense :D
How did you arrive at that path? Was it a guesstimate? or do you know summat I don't? Certainly looks a possible goer.
Having said that, it isn't quite the same shape (inlet/outlet pipes). Is this a pattern part?
Should have rest of info from Helen sometime tomorrow, and I'll post some pics of conclusions.
You have no idea how frustrating it is not to be able to do the cuts myself and get my hands on it.
Steve
The Great Pretender
Post by The Great Pretender » Thu Nov 25, 2010 12:45 am
Northern Bongolow wrote:thanks guys :) the main reason im asking is because im making this pressure monitoring gadget.
it will measure bottom end and top end pressures of the coolant system.
i was hoping to use the bottom end measurment (if its a positive pressure ) as a form of coolant leak alarm,both pressure switches are variable,so it should be of some good [-o< .it should still give an early warning of top end pressure problems,so i will bash on regardless.
just one problem that ive just managed to overcome,i bought galvanized fittings initially,but as ive found out that my red coolant attacks galv ive had to resource but im there now i think :)
Good luck with it, I considered something similar but as my coolant system has been altered a donor Bongo would have been needed.
I was thinking along the lines of a single pressure thingy in the tank working against a temp sensor (if then scenario). As the only pressure build up is temp related correlation should not be a problem as in above or below expected. EG below pressure a leak, above, stat, blockage or trapped air problem.
:wink:
To infinity and beyond
The Great Pretender
Post by The Great Pretender » Thu Nov 25, 2010 1:00 am
Yes they do, also as there is no way to vent the heaters they will increase the speed through the small bore pipes reducing the size of any air to suspended proportions then hopefully evacuating them. :wink:
The Great Pretender
Post by The Great Pretender » Thu Nov 25, 2010 1:06 am
Thanks Dandy.
Now Steve your being a lil naughty, we have to understand your pics, spend a lil time and look at it.
The collectors at the base are split in two, left half in, right half out, turn it 90deg anti clockwise and it will self vent. :roll: :wink:
widdowson2008
Post by widdowson2008 » Thu Nov 25, 2010 1:44 am
Hi TGP
Just come back from studying the pics and producing a drawing (to scale of course), and I had worked that out myself. But thanks for beating me to it. You're on the ball. :lol:
This provides the final piece (the only one I never fully understood) of the bleeding fiasco neatly into place, PROVIDING (for me) that Helen comes back and cofirms the through route, which I suspect she might.
I now fully understand the whys of the belching and farting that goes on in the bleed process and where air will, and will not, get trapped. It's a GOOD feeling. :D
I also have accurate pipe sizes, and therefore volumes.
The pipework in the Mazda matrix is constructed from thin walled aluminium and looks quite delicate. Having said that, the pipe bores look very clean.
Will publish findings ASAP.
Steve
