Re: coolant flow - (follow up to cooling diagram)
Posted: Sun Nov 21, 2010 5:13 pm
Next project - how about dissecting and graphicing (?) a viscous coupling Steve???
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
What's one of them? Have you got a sample for me to chop?dandywarhol wrote:Next project - how about dissecting and graphicing (?) a viscous coupling Steve???
If anyone wants to try that I have a in hose statdandywarhol wrote:How about fitting a thermostat on the outlet from the head?
Merciless lot aren't we? Next post from that one being "Next project..." - although that defo also means we can't get enough of you Steve.widdowson2008 wrote:So, as I said 5 pages back (is it really that far)'I think the subject line, 'COOLANT FLOW' is exhausted.' for me anyway. Can't think of owt else to bother you folk about on this one......
Ron Miel wrote: Once again, brilliant, give that man an MBE![]()
Entomology (from Greek ἔντομος, entomos0, "that which is cut in pieces or engraved/segmented",
Yep, that'll do nicelymister munkey wrote:Ron Miel wrote: Once again, brilliant, give that man an MBE![]()
Master of Bongo Entomology!!
dandywarhol wrote:A properly maintained cooling system, free from silt and crud works perfectly well when bled the Factory way - thousands of Bongos are proving that, including my old one which is still going strong with day to day use.....................................
mikexgough wrote:dandywarhol wrote:A properly maintained cooling system, free from silt and crud works perfectly well when bled the Factory way - thousands of Bongos are proving that, including my old one which is still going strong with day to day use.....................................![]()
I agree with Dandy.........Factory bleed....well flushed system .......good hoses and pipes.....correct coolant ratios etc ..............no worries...
BUT remember as vehicle owners in the UK many of us have got complacent and many don't even check their fluids,lights tyres etc between services and MOT and expect the garages to fix it annually....... Time to lose that attitude methinks.....
As I always say....... Better to do Preventative Maintainance than Reactive Maintanance......and we also need to remember a Vehicle is a Privilige not a right....
The pressure cap has overall control of the system and as the head is in direct communication with it without restriction the head will only ever see the same maximum pressure.Northern Bongolow wrote:in my opinion the head can get taken out in different ways,as you stated it could be catasrophic loss,but the usuall way is a slight prolonged loss.usually related to the number of cycles the engine has made.the motor warms up leaks under pressure,pressure drops,cools,and as the system cools it sucks in a little air.this can be from a bad clip,or holed pipe.etc
this air then accumilates and either blocks flow,or goes to the head.
depending on the amount of air,the motor continues toward meltdown.
Agree, now as most of the cooling system pipework is below the engine where will air end up? Most probably in the engine and as air rises it will end up in the head, it has to. As the air slowly displaces the coolant there is less and less coolant to dissipate the heat so the head gets hotter, the air expands pressurising the system but only as far as the system pressure.
the leaks are usually started by overpressure of the system,via a stat fault,this pressure raises the load on the entire system,and finds the weakest spot in the loop,if your hoses are good it may pop the rad.if your rad is good then it may make the pump leak.
the key to it all is the stat.
Now this is where we part companyAgree a faulty stat would cause problems.....................here it comes............
..........But an otherwise effective cooling system should show signs of a problem as there is a very effective secondary flow system.
i will get my coat.im off to the shed
Life can be annoyingThe Great Pretender wrote:
The pressure cap has overall control of the system ....
I think the only bit that hasn't been covered but very important is the pressure cap, much misunderstood. A cutaway cad pic would be very informative to the not very technical..........![]()
The main issue for Japanese owners .........other than odd radiator splits and odd hose/pipe leaks is......... Header tank pressure cap................ many just fit the standard 1.1 bar and some up the game to a 1.3 bar....... as for Thermostats ......they change with the coolant....The Great Pretender wrote:The pressure cap has overall control of the system and as the head is in direct communication with it without restriction the head will only ever see the same maximum pressure.Northern Bongolow wrote:in my opinion the head can get taken out in different ways,as you stated it could be catasrophic loss,but the usuall way is a slight prolonged loss.usually related to the number of cycles the engine has made.the motor warms up leaks under pressure,pressure drops,cools,and as the system cools it sucks in a little air.this can be from a bad clip,or holed pipe.etc
A stat on the outlet Dandy...................![]()
.............You ready for WW4?.................
Simplification helps get first principles over but doesn't this only take account of two of the dynamic processes involved?The Great Pretender wrote:>
The Great Pretender wrote: A stat on the outlet Dandy...................![]()
