Re: ABS Light on
Posted: Thu Jan 25, 2018 8:07 am
The Kia one certainly looks the closest. The tip of the sensor looks the same, the shape of the mount looks similar. The electrical plug looks the same.
My only concern was that the length of the cylinder sensor part looks shorter on the Kia one (from the mounting plate to the tip) however that might just be perspective. The mounting plate also looks to be thicker.
I seem to recall that Kia used to use a lot of parts / designs from the previous generation of cars as it was a cheap way to build a car. So that would fit in.
Most of the mazda sensors I can find have a plain metal sensor with a smooth flat tip. The bongo one is a black plastic cylinder with a small thin metal rectangle on the end. Which matches the kia Rio one.
