cmm303
Post
by cmm303 » Tue Jul 18, 2017 3:39 pm
There are no studs for the pulley, but fairly sure there are some studs between pump and head. They would be the missing bolts in the outline on this wood:
Could cross check with diagram on lush projects.
Chris with BertieB
sloppy7
- Bongonaut
Post
by sloppy7 » Tue Jul 18, 2017 6:54 pm
https://drive.google.com/open?id=0B2To7 ... EwVm1JTTJZ
Not sure if the link will work but managed to sneak my phone around and take a picture. Lushprojects and the service manual indicate 4 bolts but the fourth in my picture looks like a threaded bar with a missing nut, rather than a sheared bolt. Mildly confused at the moment but short of taking it all off and learning some I'm stumped. Or perhaps I'm missing the point completely??
sloppy7
- Bongonaut
Post
by sloppy7 » Tue Jul 18, 2017 8:08 pm
Right. New plan of attack is to flush the coolant system with rad flush as it is and whilst running the engine stick it on my ramps. Thus hopefully making the waterpump and stat change an easier job. I can't crack the three nuts remaining and I'm hoping getting underneath will give me a bit more room for leverage.
I'll also hopefully be able to locate any further leaks while doing the flush too is another part of my thinking!
cmm303
Post
by cmm303 » Wed Jul 19, 2017 12:42 am
I wonder if the Ford Ranger may use studs on the water pump because mine came with replacement studs which I didn't need for the bongo.
Chris with BertieB
sloppy7
- Bongonaut
Post
by sloppy7 » Wed Jul 19, 2017 10:45 am
Mine also came with studs hence my confusion. I have a pulley and some bolts being delivered from a breakers so if all else fails I can replace the lot. I'm now thinking I may as well replace the belts too. Does it ever end??
Also thanks for the tip on the gasket. Been quoted over £11 for it and after a 5 minute phonecall to Ford they have two coming from the factory tomorrow. At £2.77 it seemed silly to not have a spare!!
Post
by rita » Wed Jul 19, 2017 11:25 am
The Ford ranger uses studs and nuts to secure the pulley and the fan.
The Bongo WLTD use setscrews / bolts to secure the pulley and no fan .
The reason you have been sent studs is the fact that this pump fits both, but the pulley securing arrangements are diffrent.
Good Luck.
Post
by haydn callow » Thu Jul 20, 2017 4:03 pm
sloppy7 wrote:Good news.....all my parts are here. I'll get one of the clamps sent up to you Haydn early next week. Just contemplating whether to two part radflush the system once I've replaced everything.
Clamp arrived today...many thanks...I would say they are ' just the ticket' ' not as flexible as the NORMA clamps so may not be quite as good for the smaller diameter hoses...but very good value and I would use them.
Post
by haydn callow » Thu Jul 20, 2017 4:12 pm
I see 20-32 mil dia is the smallest they do...so ok but you will need Norma for the smaller pipes
sloppy7
- Bongonaut
Post
by sloppy7 » Thu Jul 20, 2017 9:47 pm
That's good news! I've not replaced any of the smaller hoses (yet!) but this thread is my reference for when I do!
Update:
1. Pipe is replaced
2.Finally cracked the thermostat housing - 750mm breaker bar did the trick after liberal dousing of 3-2-1 penetrating spray
3. Sheared a water pump pulley bolt.
4. Finally cracked the remaining two and removed the pulley, turns out there was one stud with a missing nut. (I've got a replacement pulley and bolts on the way)
5. Alternator and belts removed
6. Waterpump removed
The waterpump was disgusting on the exterior. I'm think its EGR gunk mixed with some oil seepage from the rocker cover, as my oil levels don't appear to have dropped. The innards of the pump were fairly immaculate, the thermostat was a bit "crusty".
So now all I have to do is to put it all back together and I'll be in a position to flush, fill and then bleed.
Thanks again for everyone's help.
Leigh
cmm303
Post
by cmm303 » Fri Jul 21, 2017 9:33 am
haydn callow wrote:I see 20-32 mil dia is the smallest they do...so ok but you will need Norma for the smaller pipes
Ah yes. I used spring clips (similar to Mazda originals) on smaller hoses and genuine jubilee clips on the two turbo hoses (for no other reason than I hadn't ordered the right spring clips!
sloppy7 wrote:That's good news! I've not replaced any of the smaller hoses (yet!) but this thread is my reference for when I do!
Update:
1. Pipe is replaced
Leigh
You've had a tough time.
Little tip: drop the rear heater hoses at the heater to drain a bit more of the old coolant.
Chris with BertieB
sloppy7
- Bongonaut
Post
by sloppy7 » Tue Sep 19, 2017 8:36 pm
I forgot to post up the outcome of my work with the invaluable help and advice I received on here. All replaced, flushed, refilled and bled. Engine seems to be running 2-3 degrees cooler too. Went through its MOT with a few advisories so was chuffed with that too and all set, after changing oil and filters, for an autumn trip to the Scottish Highlands in a few weeks time.
Thank you all once again.
Leigh
Post
by Bob » Tue Sep 19, 2017 8:53 pm
Well done.
