Re: Sluggish Acceleration
Posted: Fri Mar 25, 2016 10:50 pm
glad it seems to have done the trick.
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
Northern Bongolow wrote:glad it seems to have done the trick.
One on the wayNorthern Bongolow wrote:mine was a little wrinckled too but has been fine, thats not to say it couldnt be better though. i would be very interested in any results you get from buying it.------- go on , you know you want too.![]()
it looks right to me. on the ad link when you open up the details tab more info is listed, in it it says ring the seller if you have any questions.
in the old petrol carb days on bikes and cars new diaphragms were a regular service item and the motor did benefit so ------
Will doNorthern Bongolow wrote:in theory it should sharpen the response so it maybe a good cheap little tweek. keep me posted please.
Still waiting on the part. Will call today and see what the score is.Fassi wrote:Will doNorthern Bongolow wrote:in theory it should sharpen the response so it maybe a good cheap little tweek. keep me posted please.
cmm303 wrote:Success. The spring is a lot stronger than I expected and I can move the wastegate lever with pliers. Let go and it snaps shut with a thud. Next I tested the actuator with a track pump. Firstly these gauges are notoriously inaccurate so I was happy it was all in the right ball park. The wastegate did most of its opening around 20 psi, with a little more movement up to 30 psi. This is at its most open, is this what you would expect?Northern Bongolow wrote: yes anything like that should be fine, please be aware that most of these are flammable though, inside will be ok, once it starts to move just keep re applying until your happy its free. have you tested the actuator.
and a vid .... Video: Testing Wastegate
TonyBongo, this was a case of No Fault Found and my learning curve. I just didn't realise how strong the spring would be. Because it tested fine when applying pressurised air to the actuator and I had no symptomatic reason to doubt its operation, it did not really feature on my checklist when everything was back up and running. (For reasons, I'm sure will be understood, 34 new coolant hose connections were uppermost in my mindTonyBongo wrote:cmm303 wrote:Success. The spring is a lot stronger than I expected and I can move the wastegate lever with pliers. Let go and it snaps shut with a thud. Next I tested the actuator with a track pump. Firstly these gauges are notoriously inaccurate so I was happy it was all in the right ball park. The wastegate did most of its opening around 20 psi, with a little more movement up to 30 psi. This is at its most open, is this what you would expect?Northern Bongolow wrote: yes anything like that should be fine, please be aware that most of these are flammable though, inside will be ok, once it starts to move just keep re applying until your happy its free. have you tested the actuator.
Did you get to the bottom of this? Did you get the wastegate actuator moving when reconnected and engine running?
