To add to this now.Fassi wrote:List of jobs done so far.
top radiator hose replaced, new coolant, bled etc.
low coolant/temp alarm installed
air-con recharged.
new brake discs on back.
climate control transistor replaced.
no more squeaky brakes on front.
full service.
banjo filter cleaned
interior light fixed.
fridge adapted to run off leisure battery as well as EHU.
new battery
starter motor refurbished.
scavenger fan switch mod.
no more pulling to left (wheel alignment out)
new tyres all round.
running out of jobs.![]()
Thanks to all those with advice and help since end of july.
Next job is the drop links on the front. Ordered the heavy duty ones from the club shop. Any advice or tips for doing these would be most appreciated.
new front offside wishbone
advance piston seals replaced to stop leak on fuel pump
new exhaust mid section and backbox
new rear arches
new ceramic lamp holders for headlights
vacuum system reinstated as per drawing with one way valve
new glowplugs and idle tweaked to stop smoking
air inlet hose to fuel pump replaced
fuel pump diaphragm cleared of oil and cleaned
another service.
MOT pass today
still got drop links to do and will now tackle the gearbox oil etc. and some rust spots.
loving it.
