A few notes from my visit to look at Andy's Bongo. This is not an exhaustive list of the checks / work done over the past 8 or so weeks, just what I can remember:
- The cambelt timing has been checked & rechecked numerous times by at least two mechanics who have worked on dozens of V6 Bongos.
- The camshaft pulleys have been removed and checked to ensure the marks are in the correct place & the pulleys are on the correct bank
- The following have been swapped from Andy's Bongo to another: HT leads, dizzy cap, rotor arm, distributor, HT coil, igniter, crankshaft pulley & crank position sensor. They all worked fine on the other Bongo. A swap was done the other way round i.e. bits from working Bongo fitted to Andy's and it won't start.
- New plugs & rotor arm fitted.
- The distributor is driven directly from the end of one of the camshafts so no worm drive & no possibility that it can be fitted 180 degrees out.
- HT lead order checked & rechecked
- King lead cleaned of some corrosion inside the coil output
- Healthy sparks seen on all the plugs
- The fuel feed from tank has been disconnected & there is plenty of pressure from the pump.
- The petrol is quite fresh and a sample has been given a simple flammability test
- Leaky fuel line replaced
- It has a Prins LPG conversion which has not been fitted to the highest standards (loose wiring, powered by leisure battery!, etc). This sits in series with the petrol injectors so they can be switched off when running on gas. The LPG ECU has been disconnected to ensure any internal faults are not affecting the rest of the vehicle. The connections to the injectors have been remade & the signals to the injectors tested.
- Petrol is getting into the cylinders & the plugs come out wet after being turned over for a while
- EasiStart has been sprayed directly into the inlet manifold with the butterfly valve open. There is no sign of life when it turns over.
- All under-bonnet & internal fuses checked
- There is an immobiliser fitted. With it armed, there are no lights on the dash & the starter will not operate. With it deactivated, they all light up & starter works.
- ECU & temperature gauge sensors checked/swapped
- Compression test has been done & this shows all cylinders are lower than expected at around 85 psi. This has been compared to a running Bongo which is around 100. It should be between 140 & 196 psi, so while it's very low, it's unlikely to have changed from when the engine was last running.
- Tests were carried out to check the leakage past the rings and into the inlet & exhaust manifolds. This showed no obvious leak that would be the case if the valves were not closing at the correct time.
- Timing checked statically by putting no. 1 to TDC on compression stroke & checking rotor arm is pointing to no. 1 HT lead.
- Dynamic timing needs to be carried out with engine running at between 500 & 900 RPM but of course its only turning over on the starter. The distributor position looks the same as mine so is close enough to at least get a bang or splutter, but it's doesn't get that far.
- It was noted that there was some coolant (rusty coloured) found in a well in the casting under the n/s cam cover. This is outside of the head but inside the cam cover in the area where the spark plugs go. There are no coolant pipes in the area that could have leaked & no sign that is has come from within the engine either. This is a weird thing to have happened & appears unrelated to the non-starting.
- The hydraulic lifters have been seen to be doing their thing and the valves are opening & closing as expected.
- The engine shows signs of having run hot as some of the plastic components (cable conduit, mounting clips, etc) are brittle or broken. It's possible some of the wiring inside may have also been affected.
- At a point some time back while in the same garage for an MOT, a load knocking noise was heard from the bottom end. An oil change was done & there were no nasty bits & it has run fine for quite some time since then. When the engine is spun over on the starter, it does take around 30 secs for the oil light to go out. Considering the engine is not running to build the pressure up, so that's probably nothing to be overly concerned about.
- Andy has spoken to the previous owner who advised there were no similar problems. The only thing that did happen once is the engine cut out after a dunking in wet weather. This is not unheard of & I believe is caused by the crankshaft sensor getting damp. After a short period to dry out, the problem went away.
- There is one strange thing: when the engine had not been turned over for a number of hours, when trying to start it, there appears to be a sign that it has a brief attempt to run for a second or so. The cranking speed increases & it sounds like there could be some combustion. Try it again straight after & there is nothing.
- The mechanic has got the engine manual & followed many of the fault-finding steps & also attempted to read the fault codes, but there are none apparent.
The only things I've suggested he does next is:
1) call Allan in Plymouth as he is one of the most knowledgeable guys when it comes to the V6. This is planned for tomorrow.
2) remove the engine ECU to check for any visual signs of problems & unplug/re-plug all the connections a few times to ensure the pins are clean & making good contact.
There have been two similar instances reported on the forum of failing to start after cambelt replaced, but unfortunately, the people concerned never updated the threads with the outcome (good or bad).
http://igmaynard.co.uk/bongo/forum/view ... start+Belt
So over to you good folk for further discussion
