Project - Retrim and new paint
Moderator: Ian
Puma931
Re: Project - Retrim and new paint
Post by Puma931 » Wed Dec 24, 2014 1:11 pm
Glad I did this as I'm in two minds about the colour... bright green RAL 6018 with white as per the pic below, or 6011 (light sage green)??????
Puma931 wrote:Busy day at work ;-) so I decided to paint the van.
Puma931
Post by Puma931 » Mon Jan 05, 2015 10:59 am
Interior is almost finished
Really please with the rear seats :D
Paint arrived today, so I will be unbolting what I can and paint them inside. The rest of the van will have to wait until it gets warmer (March/April :? )
Spencer54
Post by Spencer54 » Mon Jan 05, 2015 12:05 pm
Wow!
Looking sharp - how easy were the front seats to fit?
Back look amazing and some work... =D>
Puma931
Post by Puma931 » Mon Jan 05, 2015 12:30 pm
The front seats were difficult, as I cut the base of the Mazda seat and welded them to the base of the Alfa GTV seats (removed Alfa runners). Overall, they are a bit too high, but fine for me and much more comfortable. I saw on ebay a guy selling RX8 seats which appear to be an easier fit. If I was doing it again, I would remove the engine covers and modify them (cut and weld base to fit wider runner base) to fit the donor seat runners.
Spencer54 wrote:Wow!
Spencer54
Post by Spencer54 » Mon Jan 05, 2015 1:34 pm
RX8 are exactly what I'm thinking of, those Alfa interiors though are beautifully made.
mantaJim
Post by mantaJim » Mon Jan 05, 2015 8:13 pm
That looks mint =D>
V6 Mushroom
Puma931
Post by Puma931 » Mon Jan 05, 2015 9:03 pm
Does the n/s rear window open, as mine does not have a latch as per the o/s rear?
Tony x
Post by Tony x » Mon Jan 05, 2015 9:13 pm
Puma931 wrote:Does the n/s rear window open, as mine does not have a latch as per the o/s rear?
Nope - as opening the slide door would smash it
jimmo62
Post by jimmo62 » Mon Jan 05, 2015 11:21 pm
Do the GTV seats (or RX8 seats if anyone knows.....) tilt forward far enough so you could still use the footrest as a rear-facing seat (and can you keep the footrest with these seats as a necessary precursor to the above question!)
Has anyone fitted any other seats where this is possible? I really fancy some leather seats but the cost of having the Bongo ones re-covered professionally is too much
Puma931
Post by Puma931 » Tue Jan 06, 2015 9:31 am
The GTV seats do tilt forward a bit as they are from a 2 door car and you can retain the foot rest.
jimmo62 wrote:Do the GTV seats (or RX8 seats if anyone knows.....) tilt forward far enough so you could still use the footrest as a rear-facing seat (and can you keep the footrest with these seats as a necessary precursor to the above question!)
Puma931
Post by Puma931 » Tue Jan 06, 2015 9:32 am
Thanks. I think I will bond a shelf to the window as my kitchen pod is on the n/s :idea: :D
Post by mikeonb4c » Tue Jan 06, 2015 10:21 am
Amazing job. Can't wait for Spring. =D> =D> =D>
philpdr
Post by philpdr » Tue Jan 06, 2015 5:20 pm
Very tasty =D> =D> .
Puma931
Post by Puma931 » Fri Jan 23, 2015 4:19 pm
starting to add some details using this
Plus I have also done the external tailgate plastic panel :D
stuc
Post by stuc » Sat Jan 24, 2015 1:04 am
Liking this thread, especially the stickerbombing
Return to “Pimp My Bongo”
