Page 4 of 5
Re: Water pump - opinions please
Posted: Mon Mar 14, 2011 12:29 pm
by widdowson2008
g8dhe wrote:Does it lead into the bearing bore? Perhaps its between the packing washer and the support bearing to allow any water that gets past the packing washer to exit before it gets into the actual support bearing and causes problems ?
Not sure without splitting the pump exactly where it goes. (Don't want to split this pump cos I have plans for it
Guessing here. Just behind the impellor, in the casing, there will be a rotary seal. For coolant to get past this seal suggests the seal is buggered.
Once past the seal, coolant is straight into the bearing, but the bearing is solid (not a ball race or needle) so what damage could it cause? and doesn't antifreeze have lubricating properties anyway? (thought I had read that somewhere)
Also, if your assumption is correct (not saying it isn't), then what is the top hole for?
Posted: Mon Mar 14, 2011 1:08 pm
by rita
widdowson2008 wrote:g8dhe wrote:Does it lead into the bearing bore? Perhaps its between the packing washer and the support bearing to allow any water that gets past the packing washer to exit before it gets into the actual support bearing and causes problems ?
Its called a weep hole,when it starts weeping water your pump is on the road out.They can also weep oil/grease if the bearing is on the same road.
Cheers..
Posted: Mon Mar 14, 2011 1:41 pm
by widdowson2008
rita wrote:widdowson2008 wrote:g8dhe wrote:Does it lead into the bearing bore? Perhaps its between the packing washer and the support bearing to allow any water that gets past the packing washer to exit before it gets into the actual support bearing and causes problems ?
Cheers..
If you were to put a grease nipple in the hole, you could inject grease to prolong the life of the pump, sort of stopgap fix? Is that what you mean?
The tell tale weep hole sounds logical, but on a Bongo, it's a bit difficult to see, even when underneath, cos there is another belt(s) in the way.
Posted: Mon Mar 14, 2011 1:57 pm
by Northern Bongolow
steve whats the position of the holes in relation to the spindle length ?. is one hole the first stage failure of one seal, then the second hole the second stage failure ie further up the shaft towards the bearing.
Posted: Mon Mar 14, 2011 2:08 pm
by widdowson2008
Holes are both obout in line.
Posted: Mon Mar 14, 2011 2:13 pm
by rita
Years ago water pumps had a grease nipple fitted,you used water pump grease,it was a heavy white grease.They now use pre packed bearings.Fitting a grease nipple now would be a waste on time.Keep your hole clear.
Posted: Mon Mar 14, 2011 2:22 pm
widdowson2008 wrote:Holes are both obout in line.
i still cannot work out why 2 holes.
any leak then should always favour the lower-- harder to view path,as yours does. this hapens quite often,and folks look at the higher easy to see top hole and pressume that the pumps not leaking.
so why 2 holes. i think it needs cutting up
Posted: Mon Mar 14, 2011 2:31 pm
by helen&tony
Posted: Mon Mar 14, 2011 2:32 pm
Posted: Mon Mar 14, 2011 3:14 pm
by widdowson2008
Yipeeeeeeeeeee
Get cutting gal (and send some pics)
Posted: Mon Mar 14, 2011 3:33 pm
by helen&tony
Hi Steve
I'll get going as soon as pump is near by courier...and our neighbour has the cutter!...Diamond jobbie!
Posted: Tue Mar 15, 2011 2:53 pm
by bigdaddycain
No antifreeze? Couldn't say. Would no a/freeze create this sort of marking? I dunno
Hi Steve, i've only just re-discovered this thread, i'm about to read the rest of it now...
I've never seent the innards of a pump "in the metal" as it were... I suggested no antifreeze as the inner chamber looks like it's been stained by rusty water.
(maybe they all look that way after a while? Dunno!)
Posted: Tue Mar 15, 2011 2:58 pm
by widdowson2008
Hi Ste
Not stained as such, more like a coating - scratches off easily back to base metal. Very similar to that cylinder head I chopped up recently.
Posted: Tue Mar 15, 2011 3:12 pm
by bigdaddycain
I see, thanks Steve.
Posted: Tue Mar 15, 2011 3:16 pm
by bigdaddycain
I'm not 100% convinced about the pocket of air in the pump spinning it up perhaps causing a rattle. Firstly would a pocket of air not be dissipated into bubbles as it was drawn into the pump? Reduced mass of the bubbled (cavitated) coolant may cause the pump to spin quicker (internal pressure must alter also) But surely this would be VERY quick? Not enough to make even a mason alarm adjusted gauge shoot up? I'm just chucking a few queries around here.
Steve, how long has the bongo been in this country? Do you know what coolant it had in it, and what coolant is in it now?
