Page 4 of 4
Re: Cutting Out & White Smoke
Posted: Sat Mar 13, 2010 7:28 pm
by mikexgough
scribe1974 wrote:I wasn't able to check the fuel tank because of the camper conversion. The vinyl flooring goes wall to wall with the cupboard units attached on top of the flooring. So assuming that the fault is not in the fuel tank I have bought a second hand fuel pump that was apparently running fine when it was on the original vehicle.
Do you good folks think I can get away with just having the pumps switched over or is it essential that I get the belts done at the same time?
Also I checked the banjo filter again, myself this time and it is completely clean although I did discover that the little allen bolt is missing. The main bolt seems to hold the thing in place ok so do I need to replace the little one urgently? I would like to replace it, so does anyone know where I can get a suitable bolt and what exactly I'm looking for?
Hope this helps........... Diesel Pump Diagram
And Diesel Pump to 99 not Fly By Wire Part Numbers
Posted: Sat Mar 13, 2010 8:10 pm
by scribe1974
Thank you very much, ZEXEL No. 010206-1040 / BOSCH No. 9 442 610 511 it is. Sorry if this is a stupid question but these numbers don't bring anything useful up on google, where do I get one from?
Posted: Sat Mar 13, 2010 8:32 pm
by mikexgough
Diesel Specialist......... Most are Bosch..... quote the Bosch part number...
these are close to you......... Fastline
Posted: Mon Mar 15, 2010 10:00 am
by scribe1974
Apologies for my being slow, I will of course just take it off the new pump temporarily.
Posted: Tue Jun 08, 2010 1:40 pm
by scribe1974
Thank you for all the responces I had on this thread.
I made a trip down to Newbury and had a new diesel pump fitted about a month or two ago and so far no cutting out so hopefully problem cured.
In future I will be far more likely to travel to a bongo specialist than have any work done by a local garage.
Once again thank you everyone for your help.
Posted: Tue Jun 08, 2010 9:24 pm
scribe1974 wrote:Thank you for all the responces I had on this thread.
Great news. Discount Trucks get rave reviews and they'll have done whatever (and only whatever) it needed to get it running right again. Happy (trouble free) motoring for summer 2010 ond on :D
Posted: Tue Jun 08, 2010 9:28 pm
by mikexgough
mikexgough wrote:I still reckon it's the diesel pump......... :roll:
I shall not say I told ya so...... :wink: .... Glad your all sorted..... =D>
Posted: Tue Jun 08, 2010 10:29 pm
but....but....but....but.....you just did #-o
Posted: Wed Jun 09, 2010 7:10 pm
by mikexgough
But I don't do it often...... :wink: ...... I just usually offer advice that I think is worth sharing
