1) air intake temperature sensor (presumably the scavenger fan one near the handbrake - swapped this out)berrega wrote:[edited] Ok. i've exhausted all the decent garages in my local area, and they've all given up.
All I have to show for it is some diagnostics .
When the engine gets warm after about 10 minutes
the glow plug starts flashing and the ECU diables the turbo as
part of a 'limp-home -mode'
The first 2 error codes given to me by the first garage
(which were 'wastegate' and boost pressure valve')
appear to be either spurious, or merely indicative of the fact the vehical was in safe mode.
The new diagnostics specialist says that 3 error codes appear similtaneously
with the flashing glowplug light, and the disabling of the turbo.
AIT is the temperature of the air in the intake system (as the defination implies) NOT the scavenger fan sensor)
2) accelerator pedal (?)
This sounds like a throttle potentiometer - makes sense as the pump is "fly by wire"
3) diesel pump pressure sensor (?)
As it implies?
Fuel pump is electronic - the injectors are as standard older design.
I'd be inclined to have the codes erased, now you've logged them, and drive it again to log more fault codes
