Page 4 of 4
Re: New springs / shocks ?
Posted: Thu May 29, 2008 11:47 pm
by dandywarhol
mayk19 wrote:those big wheels do fill the gap better, I think 16's would look good. But as I spent £200 quid on four alloys only last month think will stick with my 15's for a good while... Im just chuffed that scooby is running fine and feeling fine after a few nightmare niggles. Big south coast trip coming up in three weeks.... can't wait.
Diameter of 215/55/17 is 668mm
Daimeter of 215/65/15 is 660mm
4mm isn't going to fill the arch very much :? As Scanner says - it's an illusion............
Posted: Fri May 30, 2008 8:25 am
by scanner
I found 16" to be a good size the visual rim/tyre balance is better and there is a good choice of tyres with the right specs at reasonable cost. The slightly lower profile needed also gives a good balance of ride comfort and handling.
Posted: Fri May 30, 2008 10:41 am
dandywarhol wrote:4mm isn't going to fill the arch very much :? As Scanner says - it's an illusion............
Erm....as I said too I believe when quizzed :wink: But really it's not all illusion. The major factor is that the 17" alloy is bigger than the 15" rim. In that sense, the wheel does fill the wheel arch more. With this particular style of alloy, the large area of plain aluminium has an enhancing effect. I believe a little extra girth on the tyre also gets noticed more than you would think, especially as it has the rim of the arch as a nearby 'datum' line (assuming you notice that kind of thing at all - the wife doesn't give a stuff!). Another point not mentioned so far is that the 215 profile fills out the arch area noticeably more than a 195.
Blimey, reading the above, how sad am I (don't answer that)
Posted: Fri May 30, 2008 1:36 pm
by dandywarhol
OK, I won't :wink:
Posted: Fri May 30, 2008 10:18 pm
dandywarhol wrote:OK, I won't :wink:
Good man :lol:
