What am i looking for
If you read through the above link in my post at the top of the previous page, should answer any queries. Don't tighten it up too much, Try a TINY squirt of wd40, which should do the trick if the belt is glazed. If the belts shows signs of age or cracking, replace em. If the wd40 trick worked let us know, if you're not happy about using it, get some belt dressing which 'll do the same job
Belts n WD40
Here is the link to the 2000 uses for WD40 web page:-
http://docs-europe.electrocomponents.co ... 6dc1d9.pdf
It does mention squeaky fan belts.
