widdowson2008 wrote:
Dandy - thanks for reply - glad we are on the same page otherwise I would have wasted a lot of time barking up the wrong tree.
Mike - The above agrees with what I was saying earlier.
The reason I asked what causes the cracking was to stimulate others who do know into replying. I know NOTHING other than what I have seen myself.
I have one more animation to add (working on it at the moment). This one shows the actual path the coolant takes through the head from each of the inlets. I dont know why Mazda chose the paths, but others probably will. Post soon.
As for agreeing what was said earlier, this was raised in July about the relative heights of the "bleed" hose and the top hose outputs.....but I am not going to get into a spat about who said what and when as life is too short......
On to head cracks.......now putting the Bongo cooling system aside for now....... lets just take the engine.....nothing else......not even coolant flow....just the basic engine design.....
Having been chatting to mechanic pals and looking around the conclusions I have come to is that the faults are in the Ford design....
The same engine is fitted to Mazda BT-50 etc and the Ford Ranger (leave the Tee jobby out of this) and yet they suffer the same issues as the Bongo/Freda in respect of the heads and camshaft breakages...... There have been a couple of camshafts break in Bongo's as we know.....
The same head cracks have been reported in the BT-50/Ranger camps too....so the Bongo/Freda is not alone.....it appears to be not some singled out Bongo design fault due to the cooling system but a Ford engine design issue.
I am told.....not witnessed.....so If I am wrong please say....that the head is "thin" walled around the valve area.....and as such common sense says any overheating issues will always damage the weakest points....
The WL-T head is known to have been modified in 2001 and the WL-T engine is still being made and fitted to Rangers in certain markets like Thailand.....it is probably circumstantial that the Diesel engine option for the Bongo was withdrawn at a similar time, whether it was due to head issues or perhaps Japanese emission regulations who knows and I am sure conspiracy theories will be out there......
I guess what we need to do to conclude as to why the cracks occur and as such a problem with the WL-T engine and discover what factors lead to the failure of camshafts and what factors cause the overheating....... especially as the same problems occur with the 2 other vehicles that have a "standard" cooling system set up.....nothing like the more complex Bongo/Freda pipework
As for Heads in general...........from a reconditioner....... we don't have much to worry about......
"I think its more of a design fault than anything, the way they cast in sand does not help lol, they can have thinner walls due to the casting is one reason we were told , the aftermarket amc made heads seem to be better "
"off the top of my head and the problems
navara- older ones threw a conrod out the side of the block , cracked heads newer ones not so bad but still cracked heads
L200- cracked heads older ones were really bad newer ones we are seeing more and more but mainly blown gaskets ,you may get a new gasket to solve it
outlander- uses the vw tdi pd engines , they crack under the injector port inside and flood the oil with coolant
pajero-4m40t- they warp badly and cant be skimmed due to ceramic inserts , new head required , broken belt can wreck the camshaft caps and rockers and the camshaft , seen a few of them
freelander petrol - really bad at warping, the gasket rings bite into the head and they require skimming, we buy gasket sets in bulk for the k16 engines, they leak around the inlet manifold but most garages or owners dont notice i and whip the head off for a skim and most dont need skimmed , other get the grooves due to over heating, they require roughly 20 thou off to get flat again 40kmiles on a k16 engine is around the time they let go , more than 40kmiles and your lucky, we have heard them lasting 30kmiles after a skim and going again , there is a new multilayer gasket that is supposed to solve it but needs the bottom ladder on the engine changed i think
we dont get many freelander diesels in although i did one the other day that snapped a timing belt and bent 3 valves
the old 200tdi and 300tdi can warp badly, when they warp we have to skim it flat then drop the valves back down below the face of the head, you have 2 options then, you can get a saver shim, its a thin metal plate shaped like the gasket and it takes up the space we skim off or you drop the valves by cutting the seats , that get expensive , we opt for the shim or new head
the older cast iron ones blow a gasket get skimmed a few thou and are good to go , don't get many in due to age or many on the road
td5- most we get in are cracked as above
the
bmw engined landies crack in a bolt hole at one of the corners
toyota wl/t engined and the ford ranger-they crack between the valve seats"
Nuff said.........
