coolant flow - (follow up to cooling diagram)
widdowson2008
Re: coolant flow - (follow up to cooling diagram)
Post by widdowson2008 » Tue Sep 07, 2010 2:06 pm
The Great Pretender wrote:
widdowson2008 wrote:I'M BACK - animation duly modified. Even got bleed tube on.
Getting there, I can understand the limits of 2D pics...........but.................. :
Tried a 3D version but does it show things better or make it more understandable? Not convinced.
Steve
Post by Northern Bongolow » Wed Sep 08, 2010 5:25 am
i thought you coudnt improve on this much steve,but you have in my opinion it is easier to follow and locate the components etc.
just needs tidying up around the top hose outlet to rad,and the heater flow to the stat is a bit unclear :shock: #-o .
i dont think one is better than the other though,it depends what you want to do,and how much info your after!!
great job steve keep tweeking. =D>
widdowson2008
Post by widdowson2008 » Wed Sep 08, 2010 3:39 pm
Northern Bongolow wrote: ......in my opinion it is easier to follow and locate the components etc.
Agree about ease of locating stuff physically, but it looses on the flow around the engine
just needs tidying up around the top hose outlet to rad,and the heater flow to the stat is a bit unclear Not really sure it's worth the effort to be honest
depends what you want to do,and how much info your after!!Precisely!!! - Only did it cos TGP 'threw down the gauntlet' - thought it might be a bit of fun.
Not really sure it's any easier to follow than the other one.
Steve
daveblueozzie
Post by daveblueozzie » Wed Sep 08, 2010 4:01 pm
I think both diagrams should be used together, it makes sense using both, they compliment one another.
Lost without my Bongo.
The Great Pretender
Post by The Great Pretender » Thu Sep 09, 2010 12:31 am
I assume your cad program allows you to rotate your 3D design as all we are getting is a 2D rendition..... :lol: :lol: :lol:
I agree with DBO, they both work for me but I use ProDesktop for 3D modelling so used to 'looking' through to the other side. :wink:
To infinity and beyond
phedders
Post by phedders » Thu Sep 16, 2010 9:05 am
Hate to do a "me too" but these diagrams are brilliant. Also highlights how much "high points" there are that could trap air... which I was pondering a lot last night as I replaced the loooong hot pipe down the drivers side that goes between the two heater matrixii. (Boy that was a pig mostly because of the hidden fixing up and behind the air feeder box and the shere number of bends in the thing - but big thanks to AndyA again for splendid breaker service =D> )
mikexgough
Post by mikexgough » Thu Sep 16, 2010 12:23 pm
phedders wrote:Hate to do a "me too" but these diagrams are brilliant. Also highlights how much "high points" there are that could trap air...
Which is why the Bongo uses the De-gas tank set up...... :wink: so it continuously self bleeds when in operation..... :wink:
phedders
Post by phedders » Thu Sep 16, 2010 8:28 pm
in theory....
That depends on the flow being pressured/fast enough to move all the air I would have thought.
Location says where I am... I'd rather be justabout anywhere else! Suggestions or job offers of/in other parts of the UK gladly received...
mikexgough
Post by mikexgough » Thu Sep 16, 2010 8:38 pm
phedders wrote:in theory....
The De-Gas tank (expansion tank as we have called it) has chambers inside to act like a swirl pot to pressurise the coolant from the Radiator hot tank then forcing any air ........(that forms in the cooling system during hot/cold cycles and by cavitation at the water pump)...... out and then to feed back into the system via the heaters and thermostat bypass feed circuits.....
Post by bigdaddycain » Thu Sep 16, 2010 10:02 pm
Brilliant diagrams steve! even i can understand them! :D =D> =D> =D>
That makes a lot of sense Mike, and bears out my experiences of bongo bleeding... :wink: The only examples i've had that have been a biatch to bleed are the bongo's that have taken on gallons of air, dodgey stats, or imminent head gasket failiure, or all of the previous symptoms! :shock:
widdowson2008
Post by widdowson2008 » Tue Sep 28, 2010 9:48 am
At it again!!!!
Having gained experience and learned a few things about the graphics side of things, I did this cross section through a Mazda thermostat. As always, it is accurate - it has to be or it would be a pointless excercise. Labels will be added to show the various components and their function.
Not sure about the blue background though - any comments/suggestions?
Ultimately, my intention (if the diagram is clear enough) is to put the stat into the housing and animate the whole thing so we can see how it operates.
Steve
Post by Doone » Tue Sep 28, 2010 12:02 pm
I like blue. 8)
It may be worth asking if anyone is colour blind, are they able to see the diagram well with this shade of blue background?
Post by Northern Bongolow » Tue Sep 28, 2010 12:50 pm
nice one steve :lol: :lol: =D> .the blue is a bit bright maybe :)
widdowson2008
Post by widdowson2008 » Tue Sep 28, 2010 3:01 pm
Another one in the series
Steve
widdowson2008
Post by widdowson2008 » Sat Oct 16, 2010 8:37 am
Having cut up most bits in the Bongo cooling system, in 2 weeks I will be cutting a cylinder head open to see what the internals are like.
What I could do with before I put the knife in are suggestions as to where to make the cuts. I will only get one shot at this and would like to get it right.
Any suggestions?
Does anyone have (or can get) pics of a cylinder head viewed from all directions?
Edit: 2.5 Diesel head
Steve
