Page 3 of 4
Posted: Wed Feb 21, 2007 9:19 pm
by Big E
Would a faulty thermostat cause my problem?
Posted: Wed Feb 21, 2007 9:20 pm
by Peg leg Pete
it can cause overheating, but the water loss is puzzling
Posted: Wed Feb 21, 2007 9:22 pm
by Big E
Its not loosing water at present, it is just constantly bubbling and throwing it out the tank
Posted: Wed Feb 21, 2007 9:25 pm
by Peg leg Pete
Thats what mine did, are you getting white exhaust fumes, mine ran clear, coolant system overpressurised because of crap coolant and dodgy thermostat and airlock
Posted: Wed Feb 21, 2007 9:26 pm
by Big E
I am not getting white smoke
Posted: Wed Feb 21, 2007 9:28 pm
by Peg leg Pete
now that is a good sign, when head went on our original engine, it looked like a steam train
Is the engine oil emulsified?
Posted: Wed Feb 21, 2007 9:29 pm
by Big E
The oil looks fine, when I last looked
Posted: Wed Feb 21, 2007 9:31 pm
by Peg leg Pete
Then I doubt that head or gasket have gone, check thermostat, radiator and expansion bottle caps, make sure they bleed the system
Posted: Wed Feb 21, 2007 9:32 pm
by Peg leg Pete
bumbly what do you think
Posted: Wed Feb 21, 2007 9:33 pm
by Big E
I just hope the problem is solved soon. It would be nice to use the Bongo
Posted: Wed Feb 21, 2007 9:38 pm
by Peg leg Pete
mine was off the road almost 2 months, but in the end I changed the thermostat, replaced any dodgy hoses and clips, changed rad cap, changed expansion bottle cap, flushed the system, flushed it againand again, then filled with good quality coolant and bled the system, at that time I had not seen manual and just bled it by instinct. It has done several thousand miles now, up some big hills and the temp stays constant. Hope this does not sound bigheaded, it is not meant to
Posted: Wed Feb 21, 2007 9:41 pm
by Big E
I will pass on your advice to my Garage. Cheers
Posted: Wed Feb 21, 2007 9:44 pm
by Peg leg Pete
good luck please keep us posted on progress
Posted: Wed Feb 21, 2007 9:45 pm
by Big E
Any Bongo experts want to come and have a look at it
Posted: Wed Feb 21, 2007 9:48 pm
by Peg leg Pete
wish I could, I have a trip to Bedlington to do at some point, but not sure of time scale
If you persivere you will have your Bongo back on the road, keep positive
