Bongo cut out, black smoke, ok on driveway
Re: Bongo cut out, black smoke, ok on driveway
Post by g8dhe » Sat Mar 28, 2020 7:34 pm
The wire feeding it must come out to the LB itself, so you can see the size there and insert the fuse next to the battery in that feed. Also consider using the Cube fuses if your able to install a swap loom so that the wire to the fuse box is suitably protected;
viewtopic.php?p=681521#p681521
Chief Brody
Post by Chief Brody » Thu Apr 09, 2020 12:15 pm
Thanks again for your last post Geoff. The circuit swap loom and the new relay etc should be arriving soon. I'll update the thread with how I get on. You've been a real help. Thanks for taking the time.
