Hi Roy
The measurements for the tray my bongo had upon purchase are as follows.
Width 88mm outer edge to outer edge. Inner is 61mm. Varience is because it has a facia around edge
Height outer edge 58mm inner 46mm again it has a facia.
Depth 100mm inner, outer 121 as there are some extra plastic parts on the back of the tray.
Hope that helps
2 Din Radio
Moderator: Ian
Re: 2 Din Radio
Just to clarify the width was 88mm but the opening in my dash was more like 80mm.. The tray had two protruding lugs on each side that help to hold the tray in place the width between those is 84mm.
Re: 2 Din Radio
Hi Roy
Excellent, many thanks for your very detailed info, that should help me to buy the correct size fitting.
Thanks again Roy
Roy ( I think we'll have to call you Roy 1 and me Roy 2!)
Thanks again Roy
