Replacement hose clamps - which ones?
cmm303
Re: Replacement hose clamps - which ones?
Post by cmm303 » Mon Jan 25, 2016 9:22 pm
stuc wrote:Cheers, I did search but didn't find them.
Good fact sheet but only part numbers, no sizes
Going back to a post in 2010 courtesy of Haydn, it seems 3 different sizes were required:
12 to 20mm
20 to 32mm
32 t0 50mm
Chris with BertieB
cmm303
Post by cmm303 » Sun Feb 21, 2016 1:22 pm
With a number of forum members successfully using ordinary Jubilee clips I wondered if I was going overboard looking for constant tension clips. Certainly at £3-£6 a clip (x34) I was losing interest!
It has been a challenge finding where to buy posh clips at sensible prices in retail quantities. I have found HLC-Clamping and would appreciate any comments/experiences. It's an appalling web site that hangs all over the place so I've popped links to individual pages below.
I hope I am sorted for the medium and large hoses with the Mikalor "Jubilee" clip.
Paying £28 for a tool to do clips on the 4 small hoses grates a bit so I looked elsewhere. Mikalor W1 spring bands are readily available (e.g. on ebay here) but advertised for fuel lines, as are most small diameter spring clips. I imagine that the cooling system operates at a higher pressure so would they be ok for a coolant hose?
:? Brain aches, over thinking this :?: :roll: if I hadn't read this forum I would have just slapped on Jubilee clips throughout, done up with my massive screwdriver normally used for opening paint tins. Or can I be forgiven for not wanting to gamble with the cooling system [-o<
Chris with BertieB
helen&tony
Post by helen&tony » Mon Feb 22, 2016 5:40 am
I like the look of the first lot...I might be investing in some f those myself...With the standard Mazda clips, the only thing you must watch for is that they corrode, and those constant-pressure worm drives can be fitted without removing the hose...neat !
Post by mikeonb4c » Mon Feb 22, 2016 9:53 am
Hmmm. How does the constant tension work on those worm drives - look much like jubilee clips to my inexperienced eye :?
Post by haydn callow » Mon Feb 22, 2016 10:44 am
Look carefully and you will see a spring segment inside the clamp.....same as the NORMA CLAMPS BUT A THIRD OF THE PRICE
cmm303
Post by cmm303 » Mon Feb 22, 2016 12:20 pm
haydn callow wrote:Look carefully and you will see a spring segment inside the clamp.....same as the NORMA CLAMPS BUT A THIRD OF THE PRICE
Haydn, I've been in touch with Jo @ Haydn Alarms who was most helpful, digging through "Dad's boxes". I've thanked her.
Chris with BertieB
Post by mikeonb4c » Mon Feb 22, 2016 2:05 pm
Aha! Very cunning. Thanks Haydn
Alkers
Post by Alkers » Wed Nov 28, 2018 2:52 pm
Anyone offer an updated opinion on the worm drive clips?
I see 20-32mm, 25-40mm and 40-60mm options available which match most of the coolant sizes but i'm unsure of how many I'd need of each
Post by Ian » Wed Nov 28, 2018 3:00 pm
The external diameter of the main coolant hoses is 41 mm. For the rear heater hoses it is 22 mm.
Eratosthenes
Post by Eratosthenes » Wed Nov 28, 2018 3:23 pm
Authentic Jubilee clips correctly torqued are fine from my experiences over the years, its the imported look a likes that are the problem.
Post by haydn callow » Wed Nov 28, 2018 5:00 pm
You won’t find many makes of car that are fitted with Jubilee clamps during manufacturing, they almost all use some sort of constant pressure clamp and for good reason. Jub clamps cannot allow for the constant expansion and contraction of all the different materials involved.
TheLongRoad
Post by TheLongRoad » Wed Nov 28, 2018 5:41 pm
I used HCL and they are good quality. If the site seems to hang try a different browser. Some sites don’t handle all. You don’t need special tools
https://www.hcl-clamping.co.uk/mikalor- ... tml?cid=33
2002 Friendee 2.0 ltr Petrol.
Post by haydn callow » Wed Nov 28, 2018 6:01 pm
They look fine and reasonable price....we used to stock and supply the NORMA clamps, they were imho the best but at £3 each it could cost nearly £100 to do the full set of hoses on a Bongo. I had a phone call from McLaren Racingone day and they bought my entire stock. Haven’t bothered with them since.
Alkers
Post by Alkers » Thu Nov 29, 2018 12:25 pm
TheLongRoad wrote: Wed Nov 28, 2018 5:41 pm I used HCL and they are good quality. If the site seems to hang try a different browser. Some sites don’t handle all. You don’t need special tools
Yes they look the best and reasonable but that's only one size, how many of those and what other sizes did you use do you recall?
Post by teenmal » Thu Nov 29, 2018 2:31 pm
haydn callow wrote: Wed Nov 28, 2018 6:01 pm They look fine and reasonable price....we used to stock and supply the NORMA clamps, they were imho the best but at £3 each it could cost nearly £100 to do the full set of hoses on a Bongo. I had a phone call from McLaren Racingone day and they bought my entire stock. Haven’t bothered with them since.
Wow, that's very unusual and against McLarens policies regarding spares, do you know where they intended to use the clips ?.
Take care.
