Rear Heater - Night heater conversion
Re: Rear Heater - Night heater conversion
Post by mikeonb4c » Fri Jan 29, 2016 9:37 am
cptsideways wrote:Right done a full write up but pics are too large for some reason, can I email someone the blurb for a techy file
Woa, that was quick. If no one from Bongo Central gets back to you, send me a pm and i'll pm you my email address so you can email the stuff to me and i'll attempt to make it into a fact sheet, with you credited as author.
Post by Doone » Sat Jan 30, 2016 6:34 pm
Photo sizes are restricted and must not exceed dimensions of 800(w) x 600(h) pixels, or 100 kb in size.
If they're bigger than that, try re-sizing to see if it fixes the problem. :)
Bongolia
Post by Bongolia » Wed Oct 05, 2016 11:03 am
Did this PDF ever materialize?
Cannot find it in the factsheet area.
Looking at night heater options for the van. I have a Propex unit I was thinking of installing in place of the rear heater unit and linking into existing duct work but they can be noisy and it seems logical to run a heater on diesel rather than gas if you have a diesel motor van of course.
This heating system has a lot of upside to it.
dandywarhol
Post by dandywarhol » Sat Mar 03, 2018 12:34 pm
Excellent post - makes good reading :)
i recall having a bit of banter with the Capt'n many moons ago........................... :roll:
Post by mikeonb4c » Sat Mar 03, 2018 11:25 pm
dandywarhol wrote: Sat Mar 03, 2018 12:34 pm Excellent post - makes good reading :)
Woa! Where did you pop up from Dandy! Fantastic to see a post from you after all this time. Hope things are going well for you. :-)
Post by Bob » Sun Mar 04, 2018 1:37 am
Second that. :D
Always good to see one of the 'old lags' back here. 8)
dandywarhol
Post by dandywarhol » Sun Mar 04, 2018 11:11 am
Cheers folks.
I had a pm from a member about diesel pump seals. Been a long time since I had my fist somewhere as tight, still remember the mental scars! 8)
Had to have a browse through the posts, not a lot has changed, same old questions coming around, the search archives must be bursting :lol:
Good post about the coolant heater, I recall it being discussed a while back. There must be plenty of these Webasto Thermo Tops kicking around.
How's grumpy ol' Maynard doing?
DW.
Flanners
Post by Flanners » Sun Mar 04, 2018 12:35 pm
A post of your's helped me solve my gearbox issue with the TPS, so thank you for that....thought you were long gone. Do you still have the Bongo?
dandywarhol
Post by dandywarhol » Sun Mar 04, 2018 2:34 pm
Pleased to hear your 'box got sorted.
Haven't had a Bongo since 2010 although I still occasionally tinker on them.
I almost bought my old Bongo back last year at the motor auctions but it just exceeded my set limit. Weird seeing it again and all the little bits and bobs I'd done to it :shock:
Dabs
Post by Dabs » Sun Mar 04, 2018 5:58 pm
Bob wrote: Sun Mar 04, 2018 1:37 am Second that. :D
..............Remember this place is like Hotel California....."You can check out but you can never leave"!! :lol:
Hi Dandy!!
