Page 3 of 4
Re: Greetings from a new Bongo owner as of today
Posted: Mon Aug 10, 2015 2:37 pm
by Fassi
mikeonb4c wrote:I think it needs a good looking at when you get home. It suggests there's been neglect at some point. The crud could be clogging main and car heater radiators and that in turn could explain inability to cool properly when engine working hard. Might be worth squeezing radiator top hose when system cold to see if it crunches or is hard. That would confirm crud in system. For now, try to avoid working engine too hard. Keep us posted.
Great thanks. I'll check the hose. Still got some driving to do around Austria then the drive home to Scotland. Was up some 2000m today in it but crawled up the mountain and the highest the temp went was 99. I've brought the trusty funnel with me just in case.
Posted: Mon Aug 10, 2015 2:54 pm
I think that, with luck, you'll be OK. If its coping with all that stuff it sounds like its doing OK (although did you say you'd removed the thermostat, as that would help things esp if it was a flaky/old one!).
Posted: Mon Aug 10, 2015 3:35 pm
by Fassi
Ah no. That was some other person posting. My stat is ok.
Posted: Fri Sep 11, 2015 8:57 pm
by Fassi
Well the bongo has survived some 8000km so far across europe and back. All old problems fixed and a list as long as my arm to start on. Think I will need to move house soon and get a garage and a place to work on it instead of my tenement flat. Really could do with some sort of community garage space.
Posted: Sat Sep 12, 2015 4:32 am
by cmm303
Fassi wrote:Well the bongo has survived some 8000km so far across europe and back. All old problems fixed and a list as long as my arm to start on. Think I will need to move house soon and get a garage and a place to work on it instead of my tenement flat. Really could do with some sort of community garage space.
Just read this thread from start to finish. In two months your Bongo has gone from an abused neglected vehicle that might not make it 27 miles to the garage to a pan-European tourer. Brilliant story.
Posted: Sat Sep 12, 2015 11:14 am
by Fassi
There was lots of other problems outside of this thread but the advice on here has kept me and the Bongo going. I don't even worry about the cooling anymore or the performance as both are brilliant. Now just need to attend to the starter motor, alternator, front drop links, squeaky brakes, the disguised rust, AFT roof inserts, AFT gas struts and whatever else appears.
Bongo daft now.
Posted: Sat Sep 12, 2015 12:09 pm
Bongo daft now.
They're worth it. Mine has given me a great interest and much satisfaction after I've got jobs done and the Bongo is improved in consequence :-) And they are useful like no other car I've ever owned. \:D/
Posted: Sat Sep 12, 2015 12:51 pm
by Bob
Starter can usually be sorted with a repair kit off Flea Bay for about twelve quid.
Posted: Sun Sep 13, 2015 6:24 am
by wonkanoby
Posted: Sun Sep 13, 2015 12:09 pm
by Fassi
Bob wrote:Starter can usually be sorted with a repair kit off Flea Bay for about twelve quid.
ordered, thanks
Posted: Sun Sep 13, 2015 8:25 pm
by cmm303
Posted: Mon Sep 14, 2015 9:28 am
by Fassi
cmm303 wrote:AFT gas strut replacement: http://igmaynard.co.uk/bongo/forum/view ... lit=+Strut
Cheers :D
Posted: Mon Sep 14, 2015 12:18 pm
by Fassi
Is s symptom of the starter needing refurbed that I would turn the key and intermittently the bongo doesn't start? Just a click? I am confident it is not the battery or alternator. And a wee bit sure it isn't the starter relay as it seems to work all the time.
Posted: Fri Oct 23, 2015 12:30 pm
by Fassi
List of jobs done so far.
top radiator hose replaced, new coolant, bled etc.
low coolant/temp alarm installed
air-con recharged.
new brake discs on back.
climate control transistor replaced.
no more squeaky brakes on front.
full service.
banjo filter cleaned
interior light fixed.
fridge adapted to run off leisure battery as well as EHU.
new battery
starter motor refurbished.
scavenger fan switch mod.
no more pulling to left (wheel alignment out)
new tyres all round.
running out of jobs. :D :D :D
Thanks to all those with advice and help since end of july.
Next job is the drop links on the front. Ordered the heavy duty ones from the club shop. Any advice or tips for doing these would be most appreciated.
Posted: Fri Oct 23, 2015 7:05 pm
Fassi wrote:List of jobs done so far.
air-con recharged.
full service.
new battery
I'm well impressed. Should make and excellent drive with all that done. =D>
