Using water with no noticeable symptoms
Re: Using water with no noticeable symptoms
Post by haydn callow » Thu Nov 13, 2014 8:33 pm
Personally..I would not put stop leak/rad weld or anything else in a system except as a emergency last resort......it can help clog up a already suspect system......you could change to constant pressure hose clamps, I would bin the silicone hoses.
Distilled Waters Run Deep
Post by Distilled Waters Run Deep » Fri Nov 14, 2014 5:29 am
Whoops.... yes, jubilees. I'll mention it to the guy who fitted them. That's a drag. I remember retightening a lot of them when I first got it back as there were visible leaks. Perhaps one is leaking in a place In can't see (or easily get at).
Thanks for the stop-leak advice, though I've known Haydn to be an Oracle here...
Freda AFT: Haydn/Mason alarms + engine head temperature sensor.
Moto Guzzi California Jackal X reg
Dodgey
Post by Dodgey » Fri Nov 14, 2014 10:42 am
haydn callow wrote:Most people on here who fitted silicone hoses have since bit the bullet and binned them. They tend to start leaking when the winter temperatures arrive......
Solicone hoses don't deform and form a seal as well as rubber hoses do. It's common practice to recheck joints when converting to silicone after a few miles and correct any leaks. It's not uncommon to double-jubilee joints to prevent leaks.
My Westfield is 80% silicone now and leak free too, though I don't use it when it's very cold!
Post by haydn callow » Fri Nov 14, 2014 12:41 pm
We could knock together a LCA kit for it!!
Dodgey
Post by Dodgey » Fri Nov 14, 2014 4:07 pm
:-) I somehow doubt I'd hear it !
Post by haydn callow » Fri Nov 14, 2014 4:52 pm
We supply kits for some very heavy plant which we fit a larger siren to.
Post by Bob » Fri Nov 14, 2014 5:48 pm
I can see passers by thinking the fire truck is coming. :lol:
helen&tony
Post by helen&tony » Fri Nov 14, 2014 6:01 pm
That's the punch-line to a very old joke, Bob :lol: :lol: :lol:
Post by Bob » Fri Nov 14, 2014 6:11 pm
I'm very old, Helen. :lol:
Post by mikeonb4c » Fri Nov 14, 2014 10:23 pm
Bob wrote:I can see passers by thinking the fire truck is coming. :lol:
Whereas I was trying to work out why you'd fit an LCA to a large cabbage, until I realised he was probably talking about a large leek. :lol: :lol: :lol:
Post by Bob » Sat Nov 15, 2014 12:38 am
Ahh, just like the old days on BF. :lol:
helen&tony
Post by helen&tony » Sat Nov 15, 2014 4:34 am
Ah...
Large Cabbage Alarm....Strange, I always look for alternative words for acronyms / abbreviations....usually smutty :lol: :lol: :lol: :lol:
Post by Distilled Waters Run Deep » Sat Nov 15, 2014 1:26 pm
Thanks all -our house is a bit of a Steptoe's yard so it's apt that Steptoe's advice looks good. I don't think all that is condensation today. New pump ordered, £23 on eBay!
Dodgey
Post by Dodgey » Thu Jan 22, 2015 1:20 pm
A conclusion to this thread and my original query regarding coolant loss.
I let the garage take a look during the MOT this week and it was a simple loose hose connection where the main rad pip joins a steel pipe under the bonnet area down the bottom. I never saw it as I didn't remove the floor pan cover so it was hidden.
Pressure test revealed it, and now it all tests 100% ok.
Post by Bob » Thu Jan 22, 2015 2:17 pm
Well done. :D
