Another dash cam
Moderator: Ian
BongoBongo123
Re: Another dash cam
Post by BongoBongo123 » Fri Apr 19, 2019 4:56 pm
Good point Tony X mine froze up today. As the instructions are not the best it takes a little while to know
what is what precisely and I switched the screen saver off which means the video screen is on all the time
so over heated and froze. (We have aircon blowing at us not the windscreen)
So I have ordered 10 x mini heat sinks which I will glue on to see if that gets rid of the heat a bit quicker. I shall see.
Of course I will now turn the screen saver back on as that should reduce output of heat from device a bit.
So it has gone from great little device to a bit on the flaky side.
They call me light foot.
BongoBongo123
Post by BongoBongo123 » Mon Apr 22, 2019 3:46 pm
I salvaged a small heatsink off the chipset of an old PC motherboard that I have super glued on so will see if that helps a bit. Although I suspect it will not be as much of a problem with the screen saver on as less heat will be generated internally.
Return to “Pimp My Bongo”
