Air Lifters
Moderator: Ian
the laird
Re: Air Lifters
Post by the laird » Tue Mar 12, 2013 10:11 pm
Thinking on a set myself
windywatson
Re: Air Lifters
Post by windywatson » Wed Mar 13, 2013 7:03 pm
Go on, do it you know you want to. You wont regret it.
Windy-Watson
2001 V6 Tin Top
the laird
Re: Air Lifters
Post by the laird » Wed Mar 13, 2013 8:36 pm
Looking at air lift uk windy,the price they're asking and a set on fleabay not much diff.a few up here used matt savage so we will see
Terri & colin
Re: Air Lifters
Post by Terri & colin » Thu May 02, 2013 4:03 pm
Mine are on order... I can't wait to get them on.
Re: Air Lifters
Post by g8dhe » Wed May 08, 2013 2:25 pm
Simon mentioned needing needing to remove the springs and needing a spring compressor to fit them is this always the case ?
I'm debating with myself at the moment about getting some so just working out what might be needed, have the others who have fitted them done yourselves or had your garage fit them ?
dave_aber
Re: Air Lifters
Post by dave_aber » Wed May 08, 2013 2:27 pm
I've fitted 2 sets of these, and I can't see how you get the units into the springs through the coils, even completely unweighted. I've used a set of compressors both times.
I think I have seen it on here where people have managed to squeeze them in - but I can't imagine it's easy!
Image...Image
weebrian
Re: Air Lifters
Post by weebrian » Wed May 08, 2013 3:45 pm
Fitted mine through the coils. Not easy but straightforward with a blunt smooth bar to give a bit of leverage. WD 40 helps. First one took about 20 mins and the second one half that time. Definitely not necessary to remove the springs.
Re: Air Lifters
Post by g8dhe » Wed May 08, 2013 10:43 pm
Might have expected both responses :lol:
I think I'll have to make a purchase and then see how it goes!
Re: Air Lifters
Post by Simon Jones » Wed May 08, 2013 11:22 pm
I tried but gave up trying to feed it thru the coils as I was worried about damaging the bags. You certainly can't feed it thru the hole in the bottom of the spring as the instructions suggest. These were the spring compressors I used: £17.99 from Screwfix which is a bargain I think: http://www.screwfix.com/p/coil-spring-c ... 2pcs/45986
Re: Air Lifters
Post by g8dhe » Thu May 09, 2013 8:43 am
Thanks Simon, that is a good price but just annoying given that they will only probably be used the once!
Re: Air Lifters
Post by Simon Jones » Thu May 09, 2013 1:09 pm
Do what I did & borrow them from someone else ;). Even if you ending up buying them, it's cheaper that having to order a new unit as it's been damaged during installation. Alternatively, sell them in the Small Ads section for £10 so someone else can get some use from them.
actprime
Re: Air Lifters
Post by actprime » Thu Jun 13, 2013 10:46 am
Just fitted airlift 1000. Not easy- my hands are still aching. If you detach shocker , also release brake pipe.
Probably best to use spring compressors and remove spring . If possible fix the bottom air pipe before final positioning as it is tricky to do thru the bottom hole.
At 15psi I am now standing at 740-745 mm to centre of wheelarch -- 730 before - so I am v near the ceiling in the garage !
PinkPanther
Re: Air Lifters
Post by PinkPanther » Thu Jun 13, 2013 12:33 pm
I must have been lucky..............although arms were aching from jack up.........jack down........jack up again..........
I did use spring compressors and axle stands and that enabled me to feed the cylinders, pipes and caps in from the top, once I had dropped the rear arm a little. No other bits removed. Just made sure everything was nicely seated as I dropped everything back down again onto the wheels.
Must admit I am always nervous with compressed springs though...........even with the compressors on and all seated nicely :lol:
Return to “Pimp My Bongo”
