Page 3 of 4
Re: Continental Headlights again, sorry
Posted: Thu Aug 21, 2014 6:41 pm
by dave_aber
My Astra lamp conversion
These ones have a lever to convert RHD to LHD, so work in both markets. eBay specials "boy racer" market for Astra F
Posted: Wed Dec 31, 2014 6:11 pm
by gibbo_1000
Does anyone have any knowledge on a left hand drive headlight conversion for a facelift model? I know the Astra ones fit (with jiggery-pokery) the pre facelift, but I wanted to avoid replacing the front end just for the headlights.
Posted: Wed Dec 31, 2014 6:54 pm
by Simon Jones
Never come across anyone that has found a suitable unit to fit in place. As the indicator is built in to the same housing the chances of finding one the correct shape are very slim. You could fit the pre-facelift indicator/side light units and perhaps find a main unit to match up to it.
Posted: Wed Dec 31, 2014 7:34 pm
by dobby
I think it's been suggested before but could you fit stand alone units fitted to custom brackets
Eg
http://www.ebay.co.uk/itm/BATES-5-5-INC ... 1372736140
Posted: Thu Jan 01, 2015 5:24 am
by helen&tony
You can modify the headlamps themselves...It has been done in Russia, and apparently in Spain...What country are you living in?
Posted: Thu Jan 01, 2015 10:43 am
by Simon Jones
As Helen suggests, Russia might be a good place to get advice. I know Dimitri (DemonAV) has a facelift model with the same style HID headlamps that I've got in my 2002 Bongo. He also speaks good English (or at least better than my Russian
You can PM him via:
http://igmaynard.co.uk/bongo/forum/ucp. ... pose&u=611
Or look at his website:
http://demonav.ru/
The Russian club site is worth a look for the pictures:
http://www.mazdafriendee.ru/
Posted: Thu Jan 01, 2015 5:19 pm
by rita
gibbo_1000 wrote:Does anyone have any knowledge on a left hand drive headlight conversion for a facelift model? I know the Astra ones fit (with jiggery-pokery) the pre facelift, but I wanted to avoid replacing the front end just for the headlights.
Might be worth a shout.
http://www.european-headlights.eu/
http://completemotoringsolutions.es/Hea ... hange.html
PS does the side door meet with the requirements.
Posted: Thu Jan 01, 2015 7:05 pm
by helen&tony
Anything is worth a try, but most places will just source the LHD variant of any given car, and as the Bongo was only made in very limited numbers specifically for the Philippine market, locating spares will be like hen's teeth...Converting the lamp is the only way, and that is done by cutting out the lamp holder in the headlamp unit, and twisting it so the lamp dips left, and re-gluing the holder to the lamp, according to the instructions I've seen on the Russian site...
Posted: Thu Jan 01, 2015 7:57 pm
by Simon Jones
A quick search brings up this company based in Spain but you have to take the vehicle to them:
It may help if we knew which country gibbo is looking to use his Bongo in so we could have a hunt around.
Posted: Thu Jan 01, 2015 8:31 pm
by gibbo_1000
Guys, I live in Germany! Do we know if the headlight/ indicator 'hole' is the same shape as earlier models? I doubt it is as the bar over the bumper does not extend across the whole front. I have managed to get some lefthand Astra lights ready for the conversion but now I am a little worried I may have to get a complete front end
Posted: Fri Jan 02, 2015 12:00 am
by Simon Jones
I think you'll be ok as its mainly the grille that is deeper post-facelift. Under the skin, they're the same.
This is my '98 Bongo:
And the '02:
You may have to do some tweaking of the wiring and you will need some pre-facelift indicators as they are integral to your current headlights.
Posted: Fri Jan 02, 2015 6:26 am
by helen&tony
Hi Gibbo
No, you won't need a whole new front end...
How much time do you have to get this conversion done?...The reason I ask, is because I have a suggestion for you....namely, get an outline pattern traced of your headlight, and pop it in the car. Also, take a template of the curve at the top and bottom of the light unit, and do as I did, and look at every car you see parked, and try your patterns on them in case something looks like it will fit. BE CAREFUL not to look to suspicious
. Choose a model that is older, so you can find them in a breaker's yard!. If you find something suitable, it's just a case of making brackets to fit, and if there are gaps, tape some card in place, impregnate it with resin and paint the card, until such time as you can do the job properly come spring time.
DON'T mess with that late model grille, it's too nice...we'll find something to fit! and as sure as hell isn't frozen, we can make up some filler pieces.
First job, can you put some measurements of the grille on here, please?....I'll measure it up on mine, and see whether it will work with the Astra lights I have!...I have a few ideas in mind that might work to your advantage
Posted: Sat Jan 03, 2015 12:06 am
by gibbo_1000
We haven't actually purchased the van yet! We are collecting it in Feb half term. It is a W reg Aft with a rear 321 conversion. (According to my better half I will be changing this!!) I already have the winter wheels waiting along with the astra headlights. Once I get the van over to Germany, I will have only 45 days to register it.
Posted: Sat Jan 03, 2015 12:12 am
by gibbo_1000
Simon,
Looking at the photos you've taken, I can't see if the wings are the same shape as on later models. Does anyone know if they are? If they are, at least it would just be a bumper and grill change.
Posted: Sat Jan 03, 2015 10:43 am
by Simon Jones
The wings are the same so if you get a pair of pre-facelift indicators you will be able to use them with the Astra headlights.
