Re: Overheating: The Statistics
Posted: Mon Mar 01, 2010 2:46 pm
Errr what survey? Where was it?
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
People with problems are driven disproportionately to this site. People wishing to report something rather than nothing probably respond in greater numbers too. I'm certain that I don't read anyting like 1:5 on here having had (Bongo) head problems (are you sure the question didn't just ask if 'you had head problems'?Ian wrote:Here are some more results from the survey. When asked if the cylinder head had been replaced on your Bongo, 18.3% said yes. This figure excludes those that didn't know.
But if you ask the same question to petrol Bongo owners only, the answer is 1.0%.
He was an idiot for buying it with so many things clearly needing replacing in the near futuremikexgough wrote:Just seen this on Pistonheads.......... The subject was Cars and worst ones..........Reliable or bag of crap
This fella jumped on the BMW bandwagon.........![]()
"my 1999 E46 328CI has turned out to be a bit of a lemon, and has cost me this since i bought it late nov:
refurbed dual vanos unit - £300
set of tyres - £600
bushes - £200
wishbones - £200
disk and pads - £250
aswell as about £200 in service bits."
Unhappy with yer Bongo now...............????????
Certainly was....... but the Vamos unit failures and suspension bushes and wishbones are very common issues with Beemers so I am told.....francophile1947 wrote:He was an idiot for buying it with so many things clearly needing replacing in the near futuremikexgough wrote:Just seen this on Pistonheads.......... The subject was Cars and worst ones..........Reliable or bag of crap
set of tyres - £600
bushes - £200
wishbones - £200
Unhappy with yer Bongo now...............????????![]()
Well, I suppose the average BMW driver has the IQ of an amoeba and drives like one as wellmikexgough wrote: Certainly was....... but the Vamos unit failures and suspension bushes and wishbones are very common issues with Beemers so I am told.....
The statistician has his V6 statistics incorrect here. 140 something V6 survey respondents would equate to 1.4 petrol cylinder heads being replaced. An unlikely figure even if they do have two heads.Ian wrote:Here are some more results from the survey. When asked if the cylinder head had been replaced on your Bongo, 18.3% said yes. This figure excludes those that didn't know.
Once the "Don't Knows" were excluded, there were 101 petrol owners left. Of these, 1 had a cylinder head replaced.Glenda wrote:The statistician has his V6 statistics incorrect here. 140 something V6 survey respondents would equate to 1.4 petrol cylinder heads being replaced. An unlikely figure even if they do have two heads.Ian wrote:Here are some more results from the survey. When asked if the cylinder head had been replaced on your Bongo, 18.3% said yes. This figure excludes those that didn't know.
But if you ask the same question to petrol Bongo owners only, the answer is 1.0%.![]()
I think the petrol Bongo answer is 0.6%.
Again, the "Don't Knows" have been excluded. The actual number of replacement heads was 119; 86 replaced by current owners, 33 replaced by previous owner or dealer.Glenda wrote:Furthermore the statistics show that 71% of Diesel Bongo owners that have had the slightest coolant problem have had a new head fitted. 209 heads fitted from 292 coolant problems.
But as said previously statistics and lies..............
