Yep. Who needs it to beep when you got the mirrors closing too... Making a sound like an army of tree surgeons...csmcqueen wrote:solid ??? The earth shakesjaylee wrote:Great news! Locks with quite a solid clunk don't it.?
Ty for lettign me know but what is an actuator, you mean a rod??missfixit70 wrote:You'll need an actuator for the drivers door with that kit.
Gaza69 wrote:Ty for lettign me know but what is an actuator, you mean a rod??missfixit70 wrote:You'll need an actuator for the drivers door with that kit.![]()
Not off to a good start here am i....lol
You'll need a rod & clamps with the actuator, it's the solenoid that physically operates the lock up & down when voltage is applied across it in either direction depending on whether you're locking or unlocking it. The drivers door doesn't have one as standard which is why it won't lock if you lock the bongo from the passenger side.Gaza69 wrote:Ty for lettign me know but what is an actuator, you mean a rod??missfixit70 wrote:You'll need an actuator for the drivers door with that kit.![]()
But your better with the wordiness...missfixit70 wrote:You'll need a rod & clamps with the actuator, it's the solenoid that physically operates the lock up & down when voltage is applied across it in either direction depending on whether you're locking or unlocking it. The drivers door doesn't have one as standard which is why it won't lock if you lock the bongo from the passenger side.Gaza69 wrote:Ty for lettign me know but what is an actuator, you mean a rod??missfixit70 wrote:You'll need an actuator for the drivers door with that kit.![]()
As Jaylee just beat me to posting a picture I won't bother
Pick a window..missfixit70 wrote:Not sure if that's a compliment or an insult![]()
Or try Maplins or ebay, just look for a kit with actuators or buy an actuator seperately. You can sell or pass the spare one on to someone else if you buy a 2 actuator kit.csmcqueen wrote:I have just this minute got in from fitting mine![]()
I bought the kit from Rightclick and got the 2 wire actuator from there to
I have mounted my control unit in the door itself, connected it to a permanent negative that supplies the electric window switch (Solid Black) and the permanent live from the original central locking switch (Blue/Black) these are the only two wires you need if you're not interested in wiring up the indicator/headlights etc, although I did mount a flashing led in the door so it shows me its locked![]()
Im not sure where you got it from Colin but they are easy to wire up, its fitting the actuator thats a pita, I did make my life easier by buying a length of Mild Steel as recommended by another forum member and it's better than joining a couple of the short bars together.
Scott
Fit the two & have the best of both worlds...!missfixit70 wrote:Or try Maplins or ebay, just look for a kit with actuators or buy an actuator seperately. You can sell or pass the spare one on to someone else if you buy a 2 actuator kit.csmcqueen wrote:I have just this minute got in from fitting mine![]()
Scott
You say fit the 2, haha, i dont know the first thing about fitting one!jaylee wrote:Fit the two & have the best of both worlds...!missfixit70 wrote:Or try Maplins or ebay, just look for a kit with actuators or buy an actuator seperately. You can sell or pass the spare one on to someone else if you buy a 2 actuator kit.csmcqueen wrote:I have just this minute got in from fitting mine![]()
Scott
