Page 3 of 3
Re: interior light
Posted: Sat Jan 25, 2014 7:48 pm
by Jerzy
Thanks! Will get me some of those LEDs then
Re: interior light
Posted: Wed Jan 29, 2014 8:31 pm
by Sparticus
The light will also contain some electronic gubbins that ups the voltage to light the old tube just disconect the feed to this
Good point winchman, forgot to mention I took out the board with the 'gubbins' on and connected directly to the incoming wires. The little led discs have their own gubbins.
Also, at the risk of being quoted the ol' egg-sucking metaphor. The leds will only work one way round, so make sure you solder them all up the same way. (If you should wire them up backwards, they won't blow, just not work - apparently
Re: interior light
Posted: Wed Jan 29, 2014 11:27 pm
by the1andonly
Has anyone considered another alternative to the tubes
ie cold cathode tubes
eg
http://www.ebay.co.uk/itm/Sharkoon-10cm ... _Decals&ha
typicaly advertised for pc cases but come in various colours for the pimp brigade.
they are used in work for lighting insides of production equipment and give off good light.
down side the 12" used in work (bought off ebay) have crap inverters and are put on life test before use and are replaced by maplin product. Now this may be batch related
That last paragraph was just info and not definitive advice
would 4" or 6" fit?
Re: interior light
Posted: Sat Mar 08, 2014 12:41 pm
by peanutcrusher
I have the older type of tube light with fittings at both ends will i still be able to do this led upgrade or am i better buying the new style of light fitting and if i do buy the new type will if fit on the same points as the old one?
Re: interior light
Posted: Sat Mar 08, 2014 2:12 pm
by Simon Jones
You could do the same as Sparticus with the light you already have as you are just re-using the casing and diffuser to house the new LEDs. No point spending money on a new light and then ripping the guts out.
Re: interior light
Posted: Mon Mar 17, 2014 9:38 pm
by peanutcrusher
how do i rewire the circuit board from inside the read roof light to put a led bulb in?
http://i86.photobucket.com/albums/k96/p ... afe06c.jpg
Re: interior light
Posted: Tue Mar 18, 2014 11:11 am
I suspect the Red wire on the board is the +12 volts,
The White wire is most likely 0v,
Grey is the switched ground to choose permanent on or Door switch on, so connect the +ve of the LEDs to Red and the -ve LED to Grey on the board, throw the board itself away.
Just to say that the colour codes within modules can vary and don't necessarily match the loom colours.
Re: interior light
Posted: Tue Mar 18, 2014 12:37 pm
Interestingly mikexgough has spotted these tubes
http://www.amazon.co.uk/225mm-LED-Tube- ... uctDetails that are suggested as direct replacements. They appear to use the mains voltage via the normal choke in the fitting, however whether or not the little invertor is capable of handling the different load types will be interesting to see!
Re: interior light
Posted: Tue Mar 18, 2014 11:29 pm
by peanutcrusher
Right all done i have rewired the roof light put in two Led 16 bulb panels and removed the circuit board.
tested in the van just need to stick the two lights in place and fit back in the van.
i have taken pictures at each stage if anyone what to copy me.
Big thanks to g8dhe for your help with this and thanks to spartcus for putting the idea back in my head.
Video will follow shortly I'm post a link to my youtube channel.
Re: interior light
Posted: Wed Mar 19, 2014 7:23 am
by mikexgough
No write up with this....
but it might give some of you with U tubes an idea,,,
Re: interior light
Posted: Sun Mar 23, 2014 6:26 pm
by peanutcrusher
If anyone whats to do the same here is a video to show you how.
https://www.youtube.com/watch?v=L_digIxwxV4
Hope it helps.
