Page 3 of 3
Re: Garage Bungled Installation of Low Coolant Alarm Help Needed
Posted: Thu Feb 26, 2009 6:22 pm
by francophile1947
haydn callow wrote:And the winner of the BONGO TANK DIPSTICK is.............
Francophile1947..
Pm your address to claim your prize
Thanks Haydn, but I don't need one - I can actually see the fluid level through my tank
Posted: Thu Feb 26, 2009 10:29 pm
by westonwarrior
On the subject of coolant strength is too strong the problem or too weak?
Posted: Thu Feb 26, 2009 10:37 pm
by haydn callow
To weak.........you will get a long test "beep" and "muttering in very cold weather for the first couple of mins.
Not a big deal.
Posted: Fri Feb 27, 2009 11:21 am
by bigdaddycain
haydn callow wrote:If the alarm was flapping about there must have been a loose connection to cause it to play up...the module it'self is pretty bombproof
Thanks Haydn, you raise an interesting point, it sounds like the installer of the alarm hadn't done it properly, i'll relay the information on to the owner of the bongo in question.
Posted: Sun Mar 01, 2009 1:23 am
by bigdaddycain
New Forest Terrier wrote:Hooray!!
Problem solved thanks to Haydn and everyone.
The sender on the tank was slightly loose.
Not obvious but a small amount of movement when twisted. Tightening the attatchment screw up cured the problem.
The Bongo has been tested on Hampshire's best potholes, various bends and a rough track and not a beep except for starting up.
The temperature readout really shows up how useless the guage is. The range that registers as 11 o'clock is very wide.
Congratulations everyone
Glad it's sorted NFT
