Do you want a low coolant alarm at £22.17?
Re: Do you want a low coolant alarm at £22.17?
Post by haydn callow » Fri Feb 20, 2009 9:47 am
If thats the case, silly me , never was a strong point !!!! then you are putting in only 100 times the amount of our latest module and 53 times the old one.......much better but I'm afraid it will still be dangerously high. the above advice still stands.
(it was a test really to see if you were paying attention) :wink: :wink:
The Great Pretender
Post by The Great Pretender » Sat Feb 21, 2009 1:14 am
Thanks for the advice, did you notice I did say Maplins got the resistance wrong? Ok i'm a novice when it comes to electronics this is the first kit that I have put together so I am learning. It is now in the lower third of micro amps and said I will find out how low it will go.
Why are you reducing the amps, do you think any amps in the system are bad? Less amps the longer it takes to be a problem?
To infinity and beyond
Post by haydn callow » Sat Feb 21, 2009 9:54 am
I'm not a electricky guru myself but I do have the Engine Saver empire behind me. Their R & D dep't are very "switched on" (no pun intended)
Using high current ..as I understand it will first of all make any "probe" type sensor system uery unreliable as the "probes" will get a coating and become resistive.
Then that big hard to spell word..electrolysis..will start moving bits of metal about..then it can alter the PH of the coolant and start to destroy it's properties.
What grade of SS are your probe screws.
scanner
Post by scanner » Sat Feb 21, 2009 10:07 am
http://en.wikipedia.org/wiki/Electrolysis
Why is Dyslexia so hard to spell as well :?
The Great Pretender
Post by The Great Pretender » Sun Feb 22, 2009 12:24 am
:shock: electrolysis :shock:
Aint that how women remove unwanted hair?
The Great Pretender
Post by The Great Pretender » Sun Feb 22, 2009 12:34 am
Ok, if I look at the stainless self tappers every few months an they are still as good as new, no problem then?
Post by missfixit70 » Sun Feb 22, 2009 1:04 am
The Great Pretender wrote::shock: electrolysis :shock:
How remarkably metrosexual of you to know such things TGP :wink: :lol:
The Great Pretender
Post by The Great Pretender » Mon Feb 23, 2009 1:18 am
Im having a total body waxing the next full moon..................... :lol: :lol: :lol:
