temperature rise and no heater
Post by bigdaddycain » Tue Jan 15, 2008 9:30 pm
bigdaddycain wrote:
The bottom hose runs hotter when the stat is fully opened incidentally....
Just to clarify this point, this is my experience on one particular bongo, which had the centre core of the stat cut out as it was failing to open till it reached a constant 100 degrees.
Minutes before,the hose stayed luke warm/cool... The only reason the hose had any temperature in it, was simply down to heat soak from the other side of the stat.
The thermostat in question had effectively become nothing more than a bung, with the coolant passing over it quickly,with hardly any obstruction.
In a normal situation, where the stat is complete, the opening for the coolant is still quite restricted even with the stat fully open.
When the stat has the inner core removed, the temp guage reads just above the "c" mark,and doesn't really get much higher.
Perhaps Pat mc Kenna can confirm/correct me on this?
Hope this clears things up, glad we are all mates again.... :lol:
Post by bigdaddycain » Tue Jan 15, 2008 9:44 pm
cliffy the climber wrote:...plus another bummer is the expansion tank is so discoloured you cant see the coolant...so its a dip the finger job...yep i know whats coming by now....!
You may know what i'm about to say cliffy.... I must be clear on this!
IN MY EXPERIENCE, Bongo's with KNOWN previous overheating issues all have cloudy/discoloured expansion tanks...
But, some variables come into play here...
Expansion tanks can be cleaned. Somebody, somewhere down the line may have removed the expansion tank at some stage, and cleaned it,if it had been previously discoloured.
Those tablets for de-scaling kettles with boiling water seem to make the tanks clear(ish) again.
Some bongo's with no known overheating issues can still have a discoloured expansion bottle,which i put down to wrong coolant/insufficient coolant-water ratio,coolant system not being flushed/changed as often as it should.
A link to the above and overheating problems is debatable.
One thing is for sure,particular bongo's seem to have issues,others have none whatsoever.
What i'm trying to imply is that, if one or more areas of the cooling system fail,then its a fair bet that other problems are to follow.
I can't help with the mildew issue i'm afraid cliffy, i've had no experience of that... (touchwood) :wink:
Post by francophile1947 » Tue Jan 15, 2008 9:49 pm
cliffy the climber wrote:i have noticed a bit of mildew type stuff in the free top..so after working on the bongo earlier i give it a wipe down with disinfectant and left the eberspacher on for a couple of hours..is there a common routine for sorting this...ive spent all my life camping so i know to air tents out and make sure they are absolutely dry before packing them up..but all it has done is rain...so no chance of this...any suggestions welcome..as the bongo gets slept in most weekends...
thanks again nice people.... :D
Have a look at this thread http://www.igmaynard.co.uk/bongo/forum/ ... ght=mildew
dandywarhol
Post by dandywarhol » Tue Jan 15, 2008 10:34 pm
Well, well, well - Vanmanerik hiding in the wings 8) :lol:
The system cannot "vacuum" - the centre valve in the pressure cap(s) allow air in to the system during cooldown.
maxheadroom
Post by maxheadroom » Tue Jan 15, 2008 11:44 pm
just to let you know mine did this today and later found the water pump was leaking (see my other thread)
Keep the Faith
coco bongo
Post by coco bongo » Wed Jan 16, 2008 12:19 am
Coolant alarm is something i intend to get done soon, as BDC said it's a bongo must have.
Whats £100 odd quid compared to £500+.
Watch hoses, inspect when ever you can, consider getting a new rad, and thermostat. But most of all LISTEN TO YOUR BONGO, dont go along the lines of the old mechanics views (by turning up the radio) at any odd noises.
Get that alarm if you can afford it.
Post by bigdaddycain » Wed Jan 16, 2008 12:22 am
It's not that expensive coco, you should be able to get a Haydn alarm AND a mason alarm for around a oner... :wink:
coco bongo
Post by coco bongo » Wed Jan 16, 2008 12:30 am
What is a mason alarm? I just thought maybe its another name for coolant alarm. But obviously not. Educate me.
Post by bigdaddycain » Wed Jan 16, 2008 12:37 am
coco bongo wrote:What is a mason alarm? I just thought maybe its another name for coolant alarm. But obviously not. Educate me.
Too much info for me to respond on this one coco, if you decide to do a search input "mason AND alarm" into the search facility on techie stuff.....
Here's a link to whet your appetite...
http://www.igmaynard.co.uk/bongo/forum/ ... ason+alarm
coco bongo
Post by coco bongo » Wed Jan 16, 2008 12:39 am
Cheers BDC i am currently wetting my appatite with a brandy, gonna have a butchers at that one.
Post by bigdaddycain » Wed Jan 16, 2008 12:41 am
Good man coco! :wink: Have a good old trawl through all the threads,you'll soon be ordering the alarms mate... :wink:
coco bongo
Post by coco bongo » Wed Jan 16, 2008 12:44 am
ahhh me get's it now, thats bleddy good. Definatly worth getting both then.
Post by bigdaddycain » Wed Jan 16, 2008 12:13 pm
I'd say so.... peace of mind when you have to rush out,then realize you haven't checked the fluids for a week! :shock:
coco bongo
Post by coco bongo » Wed Jan 16, 2008 2:35 pm
Too right!!, ive got to check out the forum to see where i can purchase the mason alarm. Ill probably get one of haydns 12v ciggy lighter ones to start with.
Michael Winner
Re: No more advertising
Post by Michael Winner » Sat Jan 19, 2008 6:08 am
Socket Set Sue wrote:Can we ban any more advertising of a 'coolant loss gizmo' in the forum pages?
Surely its been mentioned enough in the Forum to get it off the ground that a paid for advert will pay for itself now.
Calm down dear! =;
