Coolant Alarm or Mason alarm?
Post by haydn callow » Thu Oct 04, 2007 8:21 am
114 !!!!!!!! where have you placed the sensor?? highest mines been is 95
You must really flog along. We tow a caravan. Our sensor is under the rocker cover front. drivers side (inlet) bolt.
clogger
Post by clogger » Thu Oct 04, 2007 8:30 am
passenger side about 2 threaded bolt holes down the cylinder head
there directly sort of
ECKY THUMP
the one true art form
Yamaha
Post by Yamaha » Thu Oct 04, 2007 1:56 pm
Never mind about all these alarms - what about my new set of gnashers!!
Mike Image
Just to get off thread - I fitted the Mason alarm yesterday - seems funny to see the gauge actually doing something - but unfortunately there aren't any decent hill to test it on here, on the Somerset Levels!!
Curator of the Bridgwater Motorbike Collection
Bonza
Post by Bonza » Thu Oct 04, 2007 6:38 pm
Mason Alarm- first thoughts after fitting.
The needle is quite active and sits at 1 oclock position and moves slightly about that point.
To calibrate the warning level I wound in down to 3 and as I drove I cranked it up very, very slowly until the warning stopped.
Next time it beeped I upped it a bit more until I have a no warning in normal use. Thats at 4 on the unit.
I havent slowly climbed a long hard hill yet but what I have noticed is that the max setting for a warning (ie the highest temp) occurs AFTER climbing a hill and then taking my foot off the accelerator and braking down hill. This produces an engine speed between idle and 1200 rpm with a slowish forward speed. Probably the water pump just idling with a poor cooling effect from the low forward speed. Accelerating the engine cancels the warning (high engine speed?).
Will report further.
Bonza
daveblueozzie
Post by daveblueozzie » Thu Oct 04, 2007 9:18 pm
thanks for that bit of info have set mine at 4 after the alarm went off at 3 as the needle got to just the 1 oclock position,will see how it goes friday on the way to silverdale.
Lost without my Bongo.
dandywarhol
Post by dandywarhol » Thu Oct 04, 2007 10:41 pm
I fitted mine tonight (quick service Dave :D ) Easy peasy to fit and ran around town tonight in L hold to get the engine hot.
Nothing sounded at 4 but as soon as I stopped and the temperature rose a little it alarmed. Now set a smigin' under 5.
Gogarth
Coolant alarm
Post by Gogarth » Fri Oct 05, 2007 4:06 pm
Well, big trip to Scotland next week, 360 miles non stop. So for peace of mind went down to see Haydn and now have a coolant level alarm fitted. It's money well spend and could help you save a small fortune. Sure there are other alarms to consider, but I think this one is a good place to start.
Grahame at work
Post by Grahame at work » Sun Oct 07, 2007 9:30 pm
As reported by me in http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=13259 I have fitted the Mason alarm and am happy with it but I have also fitted a level switch in the header tank as a coolant loss alarm. It's not wired yet as although my first attempt worked OK and alarmed under test conditons I wired it into the key in/door open buzzer (which I had previously disconnected) and I didn't check it out during the dark hours - the alarm came on as soon as I turned my lights on :oops: :oops: :oops:
A little modification to the buzzer unit should sort that - when I get time. :roll:
Anyway - I think the more instrumentation the better but I still check the coolant level every journey.
Regards Grahame
Joanie2 has had a sex change and is remaned Bert
