Compatible Parts Database
Post by Ian » Tue Mar 18, 2008 9:34 pm
Brian from Sheffield reports that a Peugeot 208 heater motor will fit the Bongo no probs.
bongomaan
Re: Compatible Parts Database
Post by bongomaan » Sun Apr 20, 2008 5:24 pm
header tank cap ...qh fc64 same as shogun
lev8
Post by lev8 » Sun Apr 27, 2008 10:04 am
Compatible brake pads not so easy to find downunder, these links give models using same pads and other pad makers part numbers
front
http://www.fujibrake.co.jp/pads/fblpad_ ... lno=AFP349
rear
http://www.fujibrake.co.jp/pads/fblpad_ ... no=AFP272S
Mazda Sentia = MS-9= 929
helen&tony
Post by helen&tony » Tue Jun 24, 2008 3:09 pm
Just done another oil/ filter change....perhaps, Ian , you could add these part nos. to the ones I put on page 1 as a more complete list:-
FIAAM FT5151
KNECHT/ MAHLE OC274
PURFLUX LS740A
TECNOCAR RD1001
I would expect the above are mostly available in Germany and Eastern Europe if you need a filter while you're travelling
waycar8
Post by waycar8 » Sat Aug 16, 2008 2:26 pm
Temperature sender unit, single pin........... part number XTT84
dandywarhol
Post by dandywarhol » Tue Aug 19, 2008 6:41 pm
waycar8 wrote:Temperature sender unit, single pin........... part number XTT84
To add to what Wayne says - the KTT 84 is a Quinton Hazel part number which also equates to INTERMOTOR 52551
QH also do a water pump - Part No. QPC3460, equivalent to MCP3460. I paid under £35 from a trade motor factor.
Post by missfixit70 » Sat Aug 23, 2008 11:31 pm
Drivers side window switches - MX3 & 626, wiring connector is different & switch mounting plate needs a little modification, but it works, £5 from a scrappy or £115 for a new one - no brainer. See this thread - http://www.igmaynard.co.uk/bongo/forum/ ... 57#p223157 - for wiring & details - thanks to Jaylee.
Post by Ian » Sat Dec 06, 2008 12:29 pm
wilba wrote:Could anyone give me the part numbers for the alternator belts please as i lost both of mine yesterday and had to be relayed from newark to norfolk. I need to replace them at the weekend so can't wait for them to arrive via t'interweb
Blueprint ADM 59621 or Gates 6474EXL
This thread is now locked. Most of the information has been placed in the updated Compatible Parts Database which you can download here:
http://www.igmaynard.co.uk/bongo/member ... #databases
If you have parts to add, please email me at ian@bongofury.co.uk
Post by missfixit70 » Thu Jan 22, 2009 1:00 pm
Please don't tell me off Ian [-o< 8-[ , saw this & thought it was too useful to lose.
apole wrote:Hi there,
The other day when I was trying to find a part for my car, I found a very useful website in China of all places.
What you do is get the part number you are after from say Lushprojects, and put it into this website.
It then gives you a detailed picture, other cars that use the same part, and who makes the part.
Doesn't work for every single part but it does for a great many.
In my case I was looking for an idle control valve, air filter and a new coil.
This is the example it comes back with on the coil.
http://www.yiparts.com/Part/en/OSHMM
Best to open in a new window otherwise the text doesn't display properly.
Remember mine is a petrol bongo, hence my example but it works for others too.
Hope you find it useful, I did not only as it has pics etc, but also know I know the other cars that use the same part it helps give me alternative places to get hold of it.
Andy
Thread now relocked
Devonduo
Post by Devonduo » Sat Jul 30, 2011 9:07 pm
Its post likes these that make me glad i joined =D>
