Page 3 of 3
Posted: Mon Oct 29, 2007 9:52 pm
by haydn callow
Just pull the bottom forwards, it should be a friction fit. If not ..remove clock and superglue a couple of small "stops" What colour does it light up?? The frame looks a little bent, you need to file off a bit of the locating lugs to correct that.
Posted: Mon Oct 29, 2007 11:49 pm
by meek.tv
thanks haydn, ill have a lookie in the daylight tomorrow and see if i can get it in a bit better.
lights up orange at the moment which is ok as the cd player is red, red or green would probably be better. do you know a part umber or bulb type for it if i decide to change him?
Posted: Tue Oct 30, 2007 12:09 am
by mister munkey
Along the same lines. . . .
I've just fitted one of Haydns clocks & mighty fine it looks too!
A couple of niggles though, the light stopped working after an hour. (haven't checked the wiring yet though) & the fit was a little tight, a bit of a squeeze width wise which has made it curve in the middle at the top & bottom. ( will have a bash at filing off a bit of locating lugs)
All in though - a very nice touch to the dash that really does look right.
Posted: Tue Oct 30, 2007 12:46 am
by dandywarhol
Tsk, tsk - fit a German clock and get German reliability.............. :wink:
Posted: Tue Oct 30, 2007 2:04 am
by bigdaddycain
Hi Meek tv & MM, there is a bit of a knack to get the surround to fit perfectly chaps...(some fit spot on first time, others dont :roll: )
The two little lugs at the top of the shroud has a recess that is supposed to slot into the ridge above.
The recess isn't quite big enough to slot into place,i used a very sharp scalpel,and a very steady hand to nibble away at the lugs till they eventually slotted in nicely.
The more time you take with the lugs, the better the fit :wink:
Don't shout at me if you chop your thumb off though! :lol: :lol: :lol:
It was a suprisingly time consuming "adjustment" I must have been fiddling with it for over an hour! (the clock! :roll: )
P.S. like the height sign,where's that from? :wink:
Posted: Tue Oct 30, 2007 9:35 am
by haydn callow
Contact me for bulbs. (THIS IS NOT A ADVERT) If you have a led bulb fitted don't forget they are polarity sensitve. If it won't work then turn 180 degrees and try again.
Posted: Tue Oct 30, 2007 12:16 pm
by meek.tv
a bit of shaving down with a craft knife and its in a lot better.
biggest improvement is i realised the iso connector was fouling something behind the cd player so it wasn't goin in all the way, bit of a tweak and a little brute force and its all sitting much nicer. thanks peops 8)
Posted: Mon Nov 05, 2007 10:10 am
by meek.tv
now glowing green. cheers haydn :D
Posted: Sat Nov 10, 2007 11:00 pm
by Pipsqueek
And the other 39?? Are you looking to find homes for these too. If so how do i go about liberating one from you for a hard currency :lol:
Posted: Sat Nov 10, 2007 11:44 pm
by haydn callow
Hi There,
For £ 22 I can put one in the post glowing whatever colour you want.
Colour and address please.
Haydn
Posted: Sun Nov 11, 2007 1:20 am
by daveblueozzie
Iv'e fitted one of Haydn's clocks a couple of weeks ago ,fantastic fitted in the slot no messing or trimming and it glows blue just like my bongo.
thanks Haydn nice job.
Posted: Sun Nov 11, 2007 1:44 am
by haydn callow
AW !! Shucks !! Stoppit Now.!!
