Page 11 of 11
				Re: Bongo 4wd refurb *DO NOT DELETE*
				Posted: Sun Aug 27, 2017 2:54 pm
				Been a while since Bongolia filed a progress report on the Wasp and another post today reminded me i'd meant to check. How's it going Bongolia - did the Wasp get flying in time to join the other wasps of summer (mind you, is it just me or have there been fewer wasps these last few years?)?
				Posted: Tue Aug 29, 2017 11:01 pm
				by Bongolia
				Been doing another refurb (a bungalow!) so it has been on the back burner for a bit. I have been running it on trade plates to sort out any bugs etc.
I have it going into a mates garage who is going to do any leveling of the bodywork and get it in primer soon as I have not the time at present. The interior remains unfitted (its a single  seater at the moment!) but this is useful for me as I will be taxing it to cart furniture from London to Kent, several trips I would think.
It burbles along quite nicely and there is more power than before the refurb. All in all a very happy bunny!
Comms here are not good, suprising as at first the 4g signal was really good but they seem to switch it off for some reason. I do log i from time to time to keep an eye on you lot though!
				Posted: Tue Aug 29, 2017 11:23 pm
				by Bob
				Posted: Wed Aug 30, 2017 7:19 am
Then again Ben new steel might weigh more than old rust
Great to get an update Bongolia - look forward to seeing next summer's wasp (not many  around this year)
				Posted: Wed Aug 30, 2017 10:11 am
				by Bongolia
Not to mention the wife
				Posted: Wed Aug 30, 2017 11:20 am
You'll have some more panel beating to do if you're not careful
				Posted: Wed Aug 30, 2017 5:39 pm
				by Bob
				Woo, don't want my panels beaten.
				Posted: Wed Aug 30, 2017 6:41 pm
				Bob wrote:Woo, don't want my panels beaten.
That's not wot i heard
Yrs
Sadie xxx
				Posted: Wed Aug 30, 2017 6:45 pm
				by Bob
				Bill, I'm not a Tory MP, Mate.
				Posted: Wed Aug 30, 2017 10:26 pm
				Posted: Sun Mar 11, 2018 12:03 am
				by Billybongo123
				Bongolia wrote: Thu Mar 30, 2017 11:38 am
teenmal wrote:When you stripped the engine did you need to bore the engine or fit pep pistons, what sort of wear did you find on the cranks / balance shafts etc.
And the old chestnut, how did the cylinders head/valves look.
Looking good.
Surprisingly, given the condition of the body, the engine was in good nick! Just serviced pistons, didnt need to hone bores, a set of crank and shell bearings general tidying up and inspection really.
It would seem from the reports from Japan, HPI and MOT records etc that the mileage , about 80000mls IIRC, is correct. As this was previously Ian Allens own it was probably very low mileage to start with.
The head was badly coked up possibly from veg oil?
So that was stripped and checked for the infamous cracking, manifolds were matched up but no flowing,exhaust manifold refaced to correct distortion, head gasket was starting to let by and we found a tiny crack in the hose spigot and all gaskets & core plugs renewed.
The injectors matched up (one odd one!)  pump was overhauled as was the box, prop UJ`s changed as they were very tight.
Other than that all good!
Next up when all is back and running will be swopping out the rear diff for an LSD and the front diff needs a bearing,  then the brakes and that should be that mex wise
Dave was meticulous in the build and so we let him choose the colours and paint the lump. Ahh bless.
Engine and box back in now but everything has ground to a halt while we try and find the brackets etc and dont ask about the cold start valve that seems to be in hiding!
I would guess about two months more and it should be back on the road,looking forward to that.
https://goo.gl/photos/VDdXskSPv6hvagZF6
What are the engine and boxes like to swap? Any tips? I need to swap my v6 lump in a few days. Never worked on a Bongo before, done loads of trucks, buses and cars though. Can't be that bad can it?
				Posted: Mon Mar 12, 2018 12:03 pm
				by Bongolia
				Drop the engine and box as one. It will come out from the bottom so a vehicle lift would be needed. I have seen a diesel lump pulled out through the top but not a method I would use , it looked a nightmare and the V6 probably worse!
Good luck
P.S. might be preaching to the converted but if you split box from engine dont forget to unbolt the flex plate and remove the torque converter with the box.
				Posted: Fri Mar 16, 2018 12:36 am
				by Bongolia
				Help needed chaps.
Just getting a start back on the Wasp and I cannot for the life of me remember where these items came from!
They are thin rubberish thingies.
https://photos.app.goo.gl/9u91HopA9NvQroC02
				Posted: Fri Mar 16, 2018 3:15 am
				by Northern Bongolow
				Posted: Fri Mar 16, 2018 12:31 pm
				by teenmal
				Here you go,the square ones 56-942b  ones attatch to the chassis behind the long bumper bracket.
http://lushprojects.com/bongopartsmk2/c ... o=.html#19
Take Care
