Leaking sill
adi999999999
Re: Leaking sill
Post by adi999999999 » Wed Apr 07, 2021 5:20 pm
The roof is an aft, why do you ask?
Re: Leaking sill
Post by rita » Wed Apr 07, 2021 8:44 pm
adi999999999 wrote: Wed Apr 07, 2021 5:20 pm The roof is an aft, why do you ask?
If it had been a sunroof on a tin top ,it could have been the drain tubes.
MightyBongo
Re: Leaking sill
Post by MightyBongo » Thu Apr 22, 2021 7:20 pm
Did anyone come to a conclusion in regards to the leaking sill mystery.
I too have found my sills leaking last week. It's not the rear heating system as that is isolated and drained.
Any findings will be appreciated.
Thanks in advance
Rach
97 2.5 TD 4WD
Re: Leaking sill
Post by Bob » Thu Apr 22, 2021 7:45 pm
I'm not sure this isn't just normal drainage.
Rickster
Re: Leaking sill
Post by Rickster » Thu Apr 29, 2021 11:43 pm
I had a similar thing happen but the water ended up on the inside where the heater unit was (removed), the aerial was the first suspect but was found to be OK, the other thing that was checked was the door switch, this was dry too.
Final conclusion was for it to be condensation, a lot of water had miraculously formed inside, enough to fill a cup in a matter of days.
The best thing to do would be to use a dehumidifier inside the van for a few days, keep the van cool thereafter and see if it happens again, if so, you have a leak.
