Page 2 of 2
				Re: Passenger side door latch
				Posted: Thu Feb 04, 2021 12:07 pm
				Yes they don't have the easiest of access, but there again you need the security and strength in those areas, there have been a couple of posts on repairing the motors that drive the locks, there all very similar internally even if the mounting boxes are different for each location.  See here
http://www.g8dhe.net/bongo_images/Slidi ... placement/ for the sliding door one.
				Posted: Thu Feb 04, 2021 3:00 pm
				by Northern Bongolow
				When you say it's banging against the catch, if you hold the outer catch open can you not rotate the lock so it goes into the unlock position and then shuts. Sometimes a strong screwdriver is needed to rotate the lock to open position as it's spring loaded.
Watch yer fingers !!.
				Posted: Thu Feb 04, 2021 4:35 pm
				by turfite9999
				Thanks Geoff and Northerner I`ll investigate further
				Posted: Thu Feb 04, 2021 8:10 pm
				Has the driver's door (master ) elbow button gone down, or come off inside etc, the button or alarm maybe locking the doors, so you may need to  pull that up to unlock the others.
				Posted: Fri Feb 05, 2021 3:39 pm
				by turfite9999
				Thanks Northern,
the latches wont let me close the door, I`m thinking one of the connecting rods dislodged
				Posted: Sun Feb 14, 2021 12:30 pm
				by turfite9999
				Hi again guys,
sorry to keep banging on about this but if locking mechanism on passenger door is broke could this effect sliding door.
Many thanks
Tony
				Posted: Sun Feb 14, 2021 12:35 pm
				Not unless the "B" pillar is out of alignment or something like that!
There is no mechanical link between the two and only the lock/unlock signal which is common to all solenoid operated doors in the electrical sense.
				Posted: Sun Feb 14, 2021 1:03 pm
				by turfite9999
				Thanks Geoff
				Posted: Mon Feb 15, 2021 2:06 pm
				by turfite9999
				Hi again I doesn't rain it pours, does anyone know how to check sliding door controller unit, it dosen`t seem to be spinning, fuses ok.
Thank you in advance.
Tony
				Posted: Mon Feb 15, 2021 2:25 pm
				The control unit is in the "B" pillar and makes its connections via the 5-button connectors (two for locking recessed), only the motor and switches are within the door.  There is a post  on repairing it here
viewtopic.php?p=696899#p696899
and a Youtube
https://www.youtube.com/watch?v=X4i2eO1CA24
				Posted: Tue Mar 02, 2021 6:07 pm
				by turfite9999
				Hi guys does anyone have or knows of anyone has the white plastic retaining clips for the sliding door rods, central locking motor please, I broke a couple removing them.
Many thanks
Tony
