Passenger side door latch
Re: Passenger side door latch
Yes they don't have the easiest of access, but there again you need the security and strength in those areas, there have been a couple of posts on repairing the motors that drive the locks, there all very similar internally even if the mounting boxes are different for each location. See here http://www.g8dhe.net/bongo_images/Slidi ... placement/ for the sliding door one.
When you say it's banging against the catch, if you hold the outer catch open can you not rotate the lock so it goes into the unlock position and then shuts. Sometimes a strong screwdriver is needed to rotate the lock to open position as it's spring loaded.
Watch yer fingers !!.
- turfite9999
- Bongonaut
Thanks Geoff and Northerner I`ll investigate further
Has the driver's door (master ) elbow button gone down, or come off inside etc, the button or alarm maybe locking the doors, so you may need to pull that up to unlock the others.
- turfite9999
- Bongonaut
Thanks Northern,
the latches wont let me close the door, I`m thinking one of the connecting rods dislodged
- turfite9999
- Bongonaut
Hi again guys,
sorry to keep banging on about this but if locking mechanism on passenger door is broke could this effect sliding door.
Many thanks
Tony
Many thanks
Tony
Not unless the "B" pillar is out of alignment or something like that!
There is no mechanical link between the two and only the lock/unlock signal which is common to all solenoid operated doors in the electrical sense.
- turfite9999
- Bongonaut
Thanks Geoff
- turfite9999
- Bongonaut
Hi again I doesn't rain it pours, does anyone know how to check sliding door controller unit, it dosen`t seem to be spinning, fuses ok.
Thank you in advance.
Tony
Tony
The control unit is in the "B" pillar and makes its connections via the 5-button connectors (two for locking recessed), only the motor and switches are within the door. There is a post on repairing it here viewtopic.php?p=696899#p696899
and a Youtube https://www.youtube.com/watch?v=X4i2eO1CA24
- turfite9999
- Bongonaut
Hi guys does anyone have or knows of anyone has the white plastic retaining clips for the sliding door rods, central locking motor please, I broke a couple removing them.
Many thanks
Tony
Many thanks
Tony
