electrical issues
papillon
Re: electrical issues
Post by papillon » Fri May 29, 2020 1:18 pm
HI,
The roof light problem was as you advised, the near side switch in the roof. The tiniest black rubber grommet had dislodged and had to be replaced (with a piece of rubber from an old pencil) :-).
The front interior fan not so. The heater works fine but the fan ( when helped to start by a gentle spin ) is very weak. On the highest setting (no.4) there is hardly a breeze coming through.
I checked the thermal switch as you advised but the connections look ok.
I have a multi meter, if there is anything you think I should check. (Not really very conversant with its operation yet though).
Thanks for your help
Post by g8dhe » Fri May 29, 2020 3:27 pm
The fan itself is worth giving a clean see here for the state they get into http://www.g8dhe.net/bongo_images/air_fan_cleaning/
The thermal fuses protect 5 resistors which control the speed of the fan in steps, if the above hasn't solved the problem, check the connectors for corrosion and that they are seated correctly on the back of the control unit in the cab, otherwise there isn't much else to go wrong. There was a report of a fan having been changed for the one the same size but it rotated in the wrong direction, the bladed fan cage itself it appeared cane from a different vehicle.
papillon
Post by papillon » Mon Jun 01, 2020 4:05 pm
hi,
The removal of the fan looks a bit challenging at the moment and I need to use the van but I will try next week. Thanks for link.
Perhaps I could ask; the interior aft light( when the roof is up) doesn't seem to be getting any power to it. I have checked the fuse and that seems to be ok and the bulb seems ok. Any suggestions please.
thanks
Post by g8dhe » Mon Jun 01, 2020 4:28 pm
If you mean the fluorescent light on the internal roof then check the cable down the roof and into the chassis, if its only failing when up then mostly likely a damaged cable at the hinges.
papillon
Post by papillon » Mon Jun 01, 2020 4:33 pm
hi,
Its the little light in the aft sleeping compartment. The flourescent light works fine.
Post by g8dhe » Mon Jun 01, 2020 4:40 pm
Ah right try cleaning the bulb contacts and the switch contacts, after that it is also controlled by one of the front microswitches that limit the roof travel when closing, it disconnects the lamp if its on to prevent battery drain. The light should go out at the same time as the beeping stops when the roof is lowered.
papillon
Post by papillon » Mon Jun 01, 2020 6:42 pm
ah...thank you, I will check front roof switch again.
papillon
Post by papillon » Sat Jun 13, 2020 7:07 pm
hi,
I haven't managed to remove fan from van yet but I wanted to ask, is there any way of testing the fan direct from 12v without removing it?
The fan seems to spin quite freely ( by hand) with no resistance.
Could you please tell me if the soldering looks ok on this image. I noticed that two of the solders seem to be touching. Not sure if it is meant to be like that;
I have a multi meter if you could sdvise where I would check to see if power is getting to the fan.
Many thanks
kevin
Post by g8dhe » Sat Jun 13, 2020 10:58 pm
Yes the fan has a connector in its lead just a few inches from the housing, if you unplug this and then jumper the connections from the motor direct to the battery it should spin up.
Yes the soldering looks OK as much as I can see in the photo!
Post by Bob » Sat Jun 13, 2020 11:41 pm
These gadgets are perfect for this kind of job:
https://www.ebay.co.uk/itm/Sealey-PP1-A ... SwotJd5mlS
Other makes and sellers out there. :wink:
papillon
Post by papillon » Sun Jun 14, 2020 11:34 am
Thanks,
Is this the connector for connecting direct to battery?
thanks
kevin
Post by g8dhe » Sun Jun 14, 2020 9:58 pm
NO!!!
The connector comes out of the fan housing itself, that is NOT the fan housing!
The cable comes from the bottom of the housing see here
Read the text and view the pictures here for how to clean out the fan and its housing http://www.g8dhe.net/bongo_images/air_fan_cleaning/
