Found and fitted these in the the end for my ‘98 diesel..
https://www.ebay.co.uk/itm/326424644295 ... Sw9vBlWIJn
I messaged the seller who asked for my reg number and advised on the correct parts, handily the even included a link to the item.
They fitted perfectly, and after applying the discount shown, were £88 for the pair, complete with brackets and have a 5-year warranty.
Not as cheap as the Daewoo ones suggested previously, but far less pfaff than cutting wires on alternative parts to suit imo.
One point to note regarding removal..
As some have experienced, the bolt holding it in place is prone to shear, I found the old mechanics trick of giving it a couple of well placed whacks with a suitable hammer (I used a drift for ‘improved accuracy’) was sufficient to ‘break the seal’ and ease removal.
(Sadly I only remembered the trick having sheared the first and had to drill/re-tap the thread).
The sensor hole required a little clean up, I used a small file to do so, and I liberally applied copper grease so things should be simpler in future (should they need removal).
						Abs sensor alternative
				Greenmachine96
 - Bongonaut
Re: Abs sensor alternative
Just jumping on this
I've got the bolt out and would like to pull the sensor out undamaged. Any idea how? Seems like the bracket (shaped like an egg/teardrop) is fused on!
