overheating issue
Re: overheating issue
Post by haydn callow » Sat Aug 24, 2019 10:26 am
Did whoever replaced the water pump know how to bleed a Bongo ? Sounds as though that was the start of the overheating problems.
Post by haydn callow » Sat Aug 24, 2019 10:30 am
I hope your Mazda garage know about Bongo cylinder heads and have done a few before, £1000 is very cheap for a main dealer garage to do the job.
Post by mikeonb4c » Sat Aug 24, 2019 11:26 am
haydn callow wrote: Sat Aug 24, 2019 10:30 am I hope your Mazda garage know about Bongo cylinder heads and have done a few before, £1000 is very cheap for a main dealer garage to do the job.
I was concerned similarly. Need to make sure also that a good quality head is fitted - i've read there are some cheap (chinese?) ones out there.
Post by rita » Sun Aug 25, 2019 12:47 pm
I doubt very much that it's a "MAIN DEALER" that is going to undertake this work.They usualy shy away from old jalopies ,unless they are desperate :shock: #-o :D
Post by mikeonb4c » Sun Aug 25, 2019 2:33 pm
rita wrote: Sun Aug 25, 2019 12:47 pm I doubt very much that it's a "MAIN DEALER" that is going to undertake this work.They usualy shy away from old jalopies ,unless they are desperate :shock: #-o :D
Haydn probably just means one of the main places/dealers for Bongos. Whilst you're here, with your knowledge of these things, what do you reckon would be a realistic price for a good quality job and how would it be best to ensure only a proper quality reolacement head is fitted?
SRMarkwell41
Post by SRMarkwell41 » Tue Aug 27, 2019 7:54 pm
mikeonb4c wrote: Sun Aug 25, 2019 2:33 pm
I got my replacement head from Bongo Spares. They're in Halifax. Came with all gaskets needed, new bolts, camshaft fitted, valves in with new guides. Runs lively so far. It's a recon. Cost £310.
Post by Bob » Tue Aug 27, 2019 10:52 pm
Bongo Spares have a good reputation. 8)
SRMarkwell41
Post by SRMarkwell41 » Tue Aug 27, 2019 11:33 pm
Bob wrote: Tue Aug 27, 2019 10:52 pm Bongo Spares have a good reputation. 8)
Had a few things from there now and never had a problem. 👍👍
