Oil change access under Friendee.
Dave Barnsley
Re: Oil change access under Friendee.
Post by Dave Barnsley » Fri Sep 06, 2019 10:23 pm
Bob, I've used the pela pump, did a 5 min run to get oil warm parked on a flat surface, checked oil showed it to be very low. Started the pump. Eventually drained 4 litres after pumping every 30 seconds am I doing something wrong. Because I put 4 litres back in and it now looks OK.
Post by Bob » Fri Sep 06, 2019 10:50 pm
A 5 minute run is very unlikely to have got Bongy up to running temp, the oil will be very thick and difficult to suck out with the Pela.
Also, if you checked the level imediately after running it will show very low as the oil will be up around the upper galleries.
Hope that helps.
Dave Barnsley
Post by Dave Barnsley » Fri Sep 06, 2019 10:54 pm
Thanks Bob, yes
Dave Barnsley
Post by Dave Barnsley » Fri Sep 06, 2019 10:58 pm
When I did first oil check it was cold and showed nearly no oil,,,,
Post by Bob » Fri Sep 06, 2019 11:11 pm
Oh dear. :(
Dave Barnsley
Post by Dave Barnsley » Sat Sep 07, 2019 2:52 pm
All sorted now Bob. Next is the atf what's the best to use. I can use the pela pump for that aswell can't I. Any tips much appreciated.
Post by Bob » Sat Sep 07, 2019 9:02 pm
Pretty sure it' Dexron 3 or higher.
Well done with the oil change. 8)
Dave Barnsley
Post by Dave Barnsley » Sun Sep 08, 2019 9:54 am
Cheers bob
