Page 2 of 2
Re: What do I need to do on my new Bongo
Posted: Tue Oct 08, 2019 1:03 pm
by Donnie
Glad to have found this thread as I just got my first bongo yesterday!!
Posted: Tue Oct 08, 2019 2:40 pm
by Bob
Congratulations on your Bongo adoption, and welcome aboard.
Posted: Tue Oct 08, 2019 4:07 pm
by Donnie
Thanks Bob, sorted insurance this morning now hunting for breakdown cover with european included
Posted: Wed Oct 09, 2019 1:02 am
by Bob
Worth checking out Gem.
They partner with a company doing Euro cover, but a good look round is best.
Posted: Thu Oct 10, 2019 5:09 pm
by haydn callow
cobbdu1 wrote: Fri Mar 01, 2019 8:18 am
g8dhe wrote: Tue Feb 26, 2019 11:38 am
A low coolant alarm - alone - which is the critical item is around £80 either direct from the site /ebay whatever, its only more expensive if you add extra temperature alarms.
Is there anything wrong with this:
https://www.ebay.co.uk/itm/Low-Coolant- ... 1532137275
As said above, it is cheap and not so cheerful, no self test every tine you switch on ignition and importantly no delay built in so false alarms can be a pain. Always fit a Low Coolant Alarm and if funds allow a Temp Alarm.
Posted: Thu Oct 10, 2019 5:15 pm
by haydn callow
A point to note, if you fit just a Temp Alarm, it could happen that your coolant leaks away overnight, drive off in the morning and you could be a couple of miles down the road before the Temp Alarm goes off...very inconvenient..... if you had a LCA fitted it would sound as soon as the ignition is switched on whilst still at home.
Just saying.
Posted: Thu Oct 10, 2019 5:39 pm
by Bob
That's exactly what mine did.
Pin hole appeared in the bleed pipe and dumped coolant overnight, alarm did what it's meant to.
