Possible Coolant System Issues
Re: Possible Coolant System Issues
Post by haydn callow » Mon Jun 25, 2018 3:02 pm
Ref resistor mod....contact forum member g8dhe
Post by teenmal » Mon Jun 25, 2018 5:05 pm
WebWiz wrote: Mon Jun 25, 2018 3:02 pm Older diesels made before particulate filters were built-in will not face the new emissions test so the mad panic to get rid of old campers before their MOT was a bit silly but tampering with any emission reducing system can result in, not only a fail, but £1000 fine.
Yes pre 2006 Diesel engine cars will still go through the old MOTT. AND as you say tampering with emissions is a Criminal offence.
WebWiz
Post by WebWiz » Sun Jul 01, 2018 1:38 pm
After much messing about, I decided to put some UV dye in the coolant.
After running for about 15mins I have spotted a tiny leak from the pipes right by the air filter near the rear heater matrix.
This would explain why I'm overheating. Not enough pressure to stop it boiling early due to a leak so small I would never have found it without UV.
I've already bought a new stat so I'll fit it anyway and also going to flush cooling system with some chemical flush.
Hopefully my drive to Isle of Wight in 2 weeks will go without a hitch. Fingers crossed.
Post by Bob » Sun Jul 01, 2018 2:38 pm
Well done.
And thanks for update. 8)
WebWiz
Post by WebWiz » Sun Jul 01, 2018 2:46 pm
I'll post a follow-up once I've done the work. Won't be until next weekend so stay tuned for the next episode.
WebWiz
Post by WebWiz » Mon Jul 02, 2018 10:44 pm
Well wouldn't you flaming well know it (probably not).
Used Transmission fluid glows under UV light. New stuff doesn't but both the leak from the gearbox cooler pipe and the dipstick glow almost the same colour as the bloody coolant trace dye.
It's actually a more yellow glow whereas the trace dye is more green.
Hey Ho. The £90 for the cooling pipes is still required but doesn't explain overheating.
I'm fitting new stat and chemical flushing engine on weekend. I'll keep you posted.
Did anyone on here know ATG glows under UV light? Weird hey!
