Page 2 of 2
Re: Transmission not selecting drive intermittantly
Posted: Thu Dec 28, 2017 8:44 pm
by cutlass
do you do stall and road test? do you do pressure test? result-in foruM!
Posted: Wed Jan 17, 2018 3:44 pm
by Alacrity
It is possible you have an internal hydraulic leak/word deformed seals/crack. If you have a hydraulic leak somewhere on the forward clutch apply circuit it may work OK when the oil is cold it is thicker, as it all warms up it thins down. If a crack these can open up with expansion when hot.
Posted: Thu Jan 25, 2018 4:35 pm
by Alkers
Posted: Fri Jan 26, 2018 3:31 pm
by cutlass
you dont disconnect tube and clean oilcooler? :(
