Transmission not selecting drive intermittantly
cutlass
Re: Transmission not selecting drive intermittantly
Post by cutlass » Thu Dec 28, 2017 8:44 pm
do you do stall and road test? do you do pressure test? result-in foruM!
Alacrity
Post by Alacrity » Wed Jan 17, 2018 3:44 pm
It is possible you have an internal hydraulic leak/word deformed seals/crack. If you have a hydraulic leak somewhere on the forward clutch apply circuit it may work OK when the oil is cold it is thicker, as it all warms up it thins down. If a crack these can open up with expansion when hot.
Alkers
Post by Alkers » Thu Jan 25, 2018 4:35 pm
cutlass
Post by cutlass » Fri Jan 26, 2018 3:31 pm
you dont disconnect tube and clean oilcooler? :(
