Page 2 of 2
Re: Replacing interior lights with LED
Posted: Mon Oct 30, 2017 9:06 pm
by mitchelln
No problem. Happy to help.
Yes, the center grey switch wire that is disconnected from the PCB is soldered to the negative wires of the LEDs.
The good thing with this mod is you can easily put it back to standard if needed
I reckon the LEDs draw about half the current of the neon.
Posted: Mon Oct 30, 2017 9:36 pm
by Roy748
Well I can vouch it's easy to convert it back..
Thanks again for your advice, I will endeavour to refit the LEDs before next camping season as the bongo is going in storage for the winter.
Posted: Tue Oct 31, 2017 3:36 pm
by Roy748
Just an update.
After your clarification I set to redoing this afternoon, total time spent 10 minutes.. as wires already spliced together and just needed soldering to the correct wire. It now works perfectly...
Thanks again for sharing this handy modification.
Posted: Tue Oct 31, 2017 4:15 pm
by mitchelln
Great! Glad you got it working
Posted: Wed Jul 15, 2020 9:25 am
by mitchelln
An update to this. The panels I originally linked to started to burnt out within 6 months. The usual over bright eBay crap.
I then switched to these, which have a built in heatsink. They are still running fine 18 months later.
https://www.amazon.co.uk/dp/B01LW3WFIE? ... b_ap_share
Posted: Wed Jul 15, 2020 12:01 pm
by Roy748
Funny enough I had a problem with the glue on the back of the LED coming away from its mounting due to it overheating. I too changed to the heat dissipation ones. I also soldered in the tiny plugs that come on each LED making it a simple job of unplugging and replacing with new LEDs should the need arise.
Posted: Tue Mar 16, 2021 8:57 pm
by Tymmuffphii
Can't u just buy a 4omm bulb for boot lamp and a T5 LED. Tube for interior light?
Posted: Tue Mar 16, 2021 9:03 pm
by mitchelln
Yup, you can use a festoon LED replacement in the rear door light. Just make sure you get a decent one with built in heatsink. Some are too fat though and don't fit.
T5 LED replacements will not fit the later Bongos with the U shaped neon tubes.
